Special Compilation Rules for Simple Library
DavidZemon
                    I just found out via another thread that wavplayer.c is supposed to be compiled with -O3, not -Os like most C/C++ source files for the Propeller. Are there any other special rules for compiling Simple?
Perhaps such things should not be in any standard library. They are probably drivers.
Or perhaps they should be supplied as precompiled objects. Compiled with the right optimizations to get them to work.
Point is, this should not be yet another detail for an application programmer to have to worry about.
Agreed. I'm asking this question on behalf of PropWare though, and I don't know if you want to consider PropWare an "application programmer."
Once PropWare has all the rules tied down, I'll be able to provide Simple as a precompiled library, and that should satisfy your points
Sorry, I missed this thread.
The wavplayer is the only library where this change was made. There's nothing else in Simple Libraries that has different optimization.
Any example code that includes the wavplayer library can also use the default optimization. It was only necessary to tweak the optimization within that particular library before compiling, but not in applications that use it.
Andy
