ActivityBot Problem - Bad Encoder?
in Propeller 1
Bought this a while ago and spent yesterday working on it with my kiddos. Assembly went smoothly but we were getting odd behaviors while playing with it. Ran the calibration (twice, actually) and got this output from the View Calibration program. Looks to me like we have a left encoder that's dead but wanted to check to confirm. Thoughts?
=== LEFT SERVO === Table Entries = 67 Zero Speed Index = 1 Index Servo Drive Encoder Ticks/Second ----- ----------- -------------------- 0 0 1000 1 0 0 2 0 0 3 0 0 4 0 0 5 0 0 6 0 0 7 0 0 8 0 0 9 0 0 10 0 0 11 0 0 12 -1 0 13 -1 0 14 0 0 15 0 0 16 0 0 17 0 0 18 0 0 19 0 0 20 0 0 21 0 0 22 0 0 23 0 0 24 0 0 25 0 0 26 0 0 27 0 0 28 0 0 29 0 0 30 150 0 31 0 0 32 4 0 33 0 0 34 0 0 35 0 0 36 0 0 37 0 0 38 0 0 39 0 0 40 0 0 41 0 0 42 0 0 43 0 0 44 0 0 45 0 0 46 0 0 47 0 0 48 0 0 49 0 0 50 0 0 51 0 0 52 0 0 53 0 0 54 0 0 55 0 0 56 0 0 57 0 0 58 0 0 59 0 0 60 0 0 61 0 0 62 0 0 63 0 0 64 0 0 65 0 0 66 0 1000 === RIGHT SERVO === Table Entries = 199 Zero Speed Index = 49 Index Servo Drive Encoder Ticks/Second ----- ----------- -------------------- 0 -195 1000 1 -193 59 2 -191 61 3 -189 63 4 -187 65 5 -185 67 6 -183 -65467 7 -181 -1 8 -179 16777215 9 -177 75 10 -175 77 11 -173 79 12 -171 81 13 -169 83 14 -167 85 15 -165 87 16 -163 89 17 -161 91 18 -159 93 19 -157 95 20 -155 97 21 -153 99 22 -151 101 23 -149 103 24 -147 105 25 -145 107 26 -143 109 27 -141 111 28 -139 113 29 -137 115 30 -135 117 31 -133 119 32 -131 121 33 -129 123 34 -127 125 35 -125 127 36 -123 129 37 -121 131 38 -119 133 39 -117 135 40 -115 137 41 -113 139 42 -111 141 43 -109 143 44 -107 145 45 -105 147 46 -103 149 47 -101 151 48 -99 153 49 5 155 50 109 157 51 111 159 52 113 161 53 115 163 54 117 165 55 119 167 56 121 169 57 123 171 58 125 173 59 127 175 60 129 177 61 131 179 62 133 181 63 135 183 64 137 185 65 139 187 66 141 189 67 143 191 68 145 193 69 147 195 70 149 197 71 151 199 72 153 99 73 155 0 74 157 0 75 159 0 76 161 0 77 163 0 78 165 0 79 167 0 80 169 0 81 171 0 82 173 0 83 175 0 84 177 0 85 179 0 86 181 0 87 183 0 88 185 0 89 187 0 90 189 0 91 191 0 92 193 0 93 195 0 94 197 0 95 199 0 96 99 0 97 -1 0 98 1 0 99 3 0 100 5 0 101 7 0 102 9 0 103 11 0 104 13 0 105 15 0 106 17 0 107 19 0 108 21 0 109 23 0 110 25 0 111 27 0 112 29 0 113 31 0 114 33 0 115 35 0 116 37 0 117 39 0 118 41 0 119 43 0 120 0 0 121 0 0 122 0 0 123 199 0 124 0 0 125 67 0 126 1000 0 127 59 0 128 61 0 129 63 0 130 65 0 131 67 0 132 -65467 -1 133 -1 -1 134 16777215 0 135 75 0 136 77 0 137 79 0 138 81 0 139 83 0 140 85 0 141 87 0 142 89 0 143 91 0 144 93 0 145 95 0 146 97 0 147 99 0 148 101 0 149 103 0 150 105 150 151 107 0 152 109 4 153 111 0 154 113 0 155 115 0 156 117 0 157 119 0 158 121 0 159 123 0 160 125 0 161 127 0 162 129 0 163 131 0 164 133 0 165 135 0 166 137 0 167 139 0 168 141 0 169 143 0 170 145 0 171 147 0 172 149 0 173 151 0 174 153 0 175 155 0 176 157 0 177 159 0 178 161 0 179 163 0 180 165 0 181 167 0 182 169 0 183 171 0 184 173 0 185 175 0 186 177 0 187 179 0 188 181 0 189 183 0 190 185 0 191 187 0 192 189 0 193 191 0 194 193 0 195 195 0 196 197 0 197 199 0 198 99 1000
It is possible that you may have some cables swapped. You can see numbers like that if you accidentally mix up a servo and encoder cable.
Check to make sure that Servo Left is connected to P12, Servo Right is connected to P13, Encoder Left is connected to P14, Encoder Right is connected to P15. Check the Electrical Connections page if you need a visual wiring diagram.
Also, double-check that the encoders are firmly plugged into the cables; sometimes they require a bit of gentle force to seat together properly. If this doesn't solve your problem, please give technical support a call or email (support@parallax.com, 888-997-8267) and they can help determine whether you'll need a new encoder for your robot.
