Can a 4-pin HC-SR04 ultrasonic sensor be used on the parallax board, i.e. with PropellerC? — Parallax Forums
I assume so.
Is there a tutorial or description.
I have an activitybot and have it working with the Parallax 3-pin sensor.
I had purchased two more sensors for use with an Arduino board I was going to try with some projects I have in mind.
I am working with my son on a maze solving robot and would like to connect three sensors.
Thanks for any help
dakotaknut
  • ercoerco Posts: 20,262
    edited 2016-01-19 03:27
    dakotaknut:
    Welcome to the forums! Yes, you can use those sensors with an Activity board. The PING is a much higher quality unit, but we've all been tempted by those $1 HC-SR04s. Like the PING shown at http://learn.parallax.com/activitybot/build-and-test-ping-sensor-circuit, you'll power it with 5V and use two resistors to interface to the 3.3V Propeller.
    The four pin HC-SR04 has seperate TRIGger and ECHO pins, requiring two Prop I/O pins. BUT... there is a top secret, insider-exclusive, eyes-only, password-protected, secret-handshake-required, simple one-resistor modification to make it function on just one I/O pin. See this long-winded thread with lots of juicy info: http://forums.parallax.com/discussion/comment/1301893/#Comment_1301893
  • OK, I found a sample that looks promising.
    https://gist.github.com/flakas/3294829#file-hc-sr04-ino-L82
    There are some build problems
    Serial.begin doesn't work, but I don't think I need it
    OUTPUT, LOW, and HIGH are all problems.
    The example didn't show the header file I would need.
    I am looking for examples of the use of these.
    For example pinMode([pin], OUTOUT);
    and digitalwrite([pin], LOW);
    LOW and HIGH are undoubtedly as simple as 0 and 1.
    I recollect seeing OUTPUT in an example sometime back when I was working on this a little bit.
    I would like to use a header file for these. I assume that would be the best.
    Thank you
  • Hey, thank you, because my sample doesn't seem to be panning out like I was thinking it might.
    I can't wait to take a look at this.
  • anxanywhereanxanywhere Posts: 1
    edited 2020-04-21 13:54
    Probably no one is still after this anymore, but I was able to use a 4-pin HC-SR04 with Propeller Activity Board (this was based on https://gist.github.com/flakas/3294829#file-hc-sr04-ino-L82 code)
    #include "simpletools.h"
    /* HC-SR04 Sensor
       https://www.dealextreme.com/p/hc-sr04-ultrasonic-sensor-distance-measuring-module-133696
       This sketch reads a HC-SR04 ultrasonic rangefinder and returns the
       distance to the closest object in range. To do this, it sends a pulse
       to the sensor to initiate a reading, then listens for a pulse
       to return.  The length of the returning pulse is proportional to
       the distance of the object from the sensor.
       The circuit:
    	* VCC connection of the sensor attached to +5V
    	* GND connection of the sensor attached to ground
    	* TRIG connection of the sensor attached to digital pin 14
    	* ECHO connection of the sensor attached to digital pin 15
       Original code for Ping))) example was created by David A. Mellis
       Adapted for HC-SR04 by Tautvidas Sipavicius
       This example code is in the public domain.
    const int trigPin = 14;
    const int echoPin = 15;
    int main()
      while(1)
        // The sensor is triggered by a HIGH pulse of 10 or more microseconds.
        // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
        low(trigPin);
        pulse_out(trigPin, 10);
        // Read the signal from the sensor: a HIGH pulse whose
        // duration is the time (in microseconds) from the sending
        // of the ping to the reception of its echo off of an object.
        long tEcho = pulse_in(echoPin, 1);
        // convert the time into a distance
        int inDist = tEcho / 148;
        int cmDist = tEcho / 58;
        print("%d inch\n", inDist);
        print("%d cm\n", cmDist);
        pause(200);
  • Welcome back after 4 years. All working code is most welcome. The HC-SR04 is pretty prevalent on ebay.
