Robo to robo location detection help
in Robotics
I have 2 BOE bots and I need both of them to know where the other is. I want to have a little bot run around and pick up small items and put them in the back of a truck and then from there the truck will deposit the items and come back for the little bot and pick it up. Then go back go the dock. Right now I am using IR for wall and object detection but I can use sonar and RF.
I was planning on just having a system of a ring of IRs and then haveing a total of 12 IR transistors so that it can detect at all times. My next question is how does sonar systems work and do you know a good place to get cheap ones? I found them for $8 on amazon and i think that is what i will go with
The ring of IR receivers is a great idea. Provides a rough location that can be narrowed down by having the robot turn. No extra motors or mechanical system required. Not sure how well the sonar would work. Seems to me the range is a bit on the short side for this.
My issue is that i can not then have wall detection
Edit: Then again maybe not, because both IR locators would need to be on at the same time... That would take some experimentation.
eBay is a good place to get cheap ultrasonic, just be careful some are 4 wire and require much different setup than the 3 pin Parallax sells.
I didn't realize these were for wall detection. Still, no reason you couldn't add an IR receiver to detect the beacon signal. Might even add a transmitter and use a retroreflector instead of a beacon.
I think i will try your method even tho the boe borde has a slow clock speed. And i am already having the borde in a old RC humve body and such. I can work with it if it turns out being a 4 pin. And I am using this for a high school compatition and funding it my self. So i need to stay on the cheap side and learn how to use what i have to work with
Martin, this looks like the best way to have a robot find it's charging station, I would like to have the robot make it's own call, through ADC to head for recharge, that willl have to be a variable, and depend on distance it will have to travel. So as not to run out of gas getting there.
_mike
But the Pololu IR beacons are pretty sweet too, they allow a robot to turn off and on the IR emission versus detection function. If you have another channel of communication between a pair of robot (e.g. Bluetooth, XBees, or Wixels) you can coordinate their IR usage to avoid collision and let both bots use IR for more than just beacons.
Edit: I used and wrote about this sensor at http://servo.texterity.com/servo/201512/?folio=44&pg=44#pg44
Do not bother with 3-pin modules, which only use DC IR light levels.
http://www.ebay.com/itm/311523477616
Extended range when a big Scotchlite reflector is used. Coupled with an ultrasonic sensor to verify range, you could so some impressive feats .
@erco
That setup looks great for indoor use, and will be the path I take for my Activity Bot, you guys are having a lot of fun with the BoeBot types, I have the gripper on mine and need to start working with it, I am missing out.
Interested in my options for outdoor use,
I followed cmdr erco's recommendations,
and have recently finished the code for the Gimbal Joystick remote control, I now have proportional steering and throttle, also will be employing the Ackermann steering geometry,
it should be achived fairly easy on my robot, shortening the tie rod and some re-adjustment plus coding changes, I should have done the latter first, but I have had limited mobility for over week. Will be incorporating long range radios for control, and long range video/audio.
As Martin mentioned to me, GPS will keep me in the ballpark of where and where not to go, ping sensors work outside maybe not as good as indoors, but if I lost video, control or just need a re-charge, I want it to head back home on it's own, must keep it out of the road.
