Microphone Preamp
1) Anybody need a $4 "professional" microphone stocking stuffer for their rockstar kids? http://www.walmart.com/ip/Pyle-Professional-Moving-Coil-Dynamic-Handheld-Microphone-Silver/20659775
2) Anybody have a favorite one-transistor preamp for such a dynamic (moving coil) mike? I need to feed two such mikes into the AUX input (stereo, one on left, one on right) of a car stereo.
This is one I found so far: http://www.epanorama.net/circuits/micamp.html
In the referenced circuit, drop R1, C1 and C2, which are meant only for an electret mic, also drop the red led ("to show that the circuit operates"? You'll know!). I'd add another resistor of say 39kΩ from the base of the transistor to ground. That will raise the DC voltage on the collector of the transistor closer to the middle of the 9V power supply range. The circuit bias will be around 2mA. And as another step, break the direct connection of the transistor emitter to ground and fill the break with a 100Ω resistor in parallel with a capacitor of 10 to 100µF. The two extra resistors stabilize the operating point and improve the linearity to make it sound better, and the capacitor restores the high gain to make it punch through. Bring on the rockstar kids and dad!
If you have a bag of 2N2222A's, I suggest you take out your ebay component tester and find a pair of transistors for your stereo amplifier that are fairly well matched in terms of Vbe and gain, and pass up on ones that have an exceptionally low gain. You will find quite a spread. The gain of this circuit we are talking about with the emitter grounded will depend very much on the gain (Hfe, beta) of the transistor itself. You want a voltage gain of around 40dB, which is 100x. The transistor needs an Hfe above that.
Here is a nice hobbiest explanation of transistor characteristics...
http://www.aoc.nrao.edu/~pharden/hobby/HG_DS1.pdf
I have used this circuit with Electret mics with pleasing results. I have not tried it with dynamic mic, however in a similar circuit I have used a magnetic pickup coil in the same location where you would place the dynamic mic. The dynamic mic should work in the same place in the circuit as an Electret mic.
Can Tracy and Beau save Christmas with a simple one-transistor autotune circuit? Dig deep, guys!
SLOOOOOOOOOOOW Fourier Transform.
When I first ever saw an FFT it was written in BASIC for the Atari ST.
It was SLOOOOOOOOOOOW....
I think the BS2 might need many more "OOO" in there
The common base configuration for audio preamp circuit is neat, vintage Beau. The current gain is less than one (beta/(beta+1)), so the voltage gain will depend strongly on how much current the mic can support into the emitter of the transistor. The frequency response is probably good, a characteristic of common base.
After I built the preamp.
After I went to Fry's yesterday to buy a new HD.
Today only, this complete 2-wireless mike system is on sale for $12 at Fry's: https://shop1.frys.com/product/6709545
Trying. To. Resist. Going. Back. To. Fry's.
Weakening.
Failing.
My 10 yo nephew prefers Oingo Boingo.
Hi,
Sorry for resurrecting an old thread:
I was wondering where one would add a potentiometer for a volume control to this.
Would it be at the input between the mic and the transistor, or would it be at the output
after the 1uF capacitor?
I assume the potentiometer would have a different value depending on where one places it?
Thanks for the help
