Is it possible to switch external oscillators?
Hi All, sorry for stupid questions in advance! I'm just a nub wanted to know more...
The question is - is it possible to dynamically change the external oscillators?
What I mean is: imagine we have 3 different external oscillators (for different purposes - 5.0MHz, 6,25MHz and xyzMHz), we have of course pins (or any other HW abilities) to select the desired oscillator.
My question is: are we able to phisically change the real external oscillator?
By "phisically" I meant "dynamically switch external oscillators from the cog's code while being able to control the situation".
1. We have a lot of VGA drivers already but there is still no universal VGA driver for any particular purposes.
2. To be "all-purposes VGA driver" an application should be able to switch between many of xVGA timing options.
3. kuroneku is the King in non-waitvid hi-res applications but his state-of-the-art drivers are tied with the bandwidth factors.
4. another available waitvid-based VGA-drivers are also tied up to a specific pixel-rates.
that's why I asked of a way of HW swiching between oscillators - it would be possible to create an "universal" VGA driver to support most of the supported modes of visualisation (simply by loading a cog/cogs by an appropriate driver by a request from the user side).
It would probably work if you switched the propeller to internal clock during the change over.
Bean
Hi, Bean
Is it means that even when switching between internal/external frequences at the same rate there are the problems arises?
1. I'm a Spin code that is runing NOW at a fixed X MHz (external), a VGA-driver in a cog is displaing something;
2. Now I (the spin code) have got somehow (either by pin observing or by monitoring a value in the main RAM or somehow else) the knowledge that I have to change the external oscillator frequency (mainly becourse a user have changed a video-mode);
3. I switch to the internal oscillator temporarily;
4. I just change the state of pre-defined pins (or send a command by SPI or inform another cog to do it etc.) to select ANOTHER external oscillator (from the set of availables);
5. Me (or another cog) changes (selects) another external oscillator;
6. I switch from the internal frequency (see point 3) to the selected external oscillator (Y MHz).
7. I (re)load a cog with the appropriate VGA driver;
8. The user sees the video-mode he expected (640x480, 720x400, 800x600, 1024x768 - from 80x30 8x16-font ending up to 128x96 8x8-font chars with different foreground/background/blink attributes, with 256x192 pseudo-graphics).
Would it work?
Bean
No, I think that is okay. We were switching between two external frequency sources.
Bean
Sorry, I was confused by "it would lock up the propeller sometimes".
So, you think it IS possible, doesn't you? (I mean it's possible to dynamically change external oscillators)
It sounds good! ))
I'm not an electronic engineer - how could the scheme with oscillators demultiplexing would be drawn?
I just need an idea - I don't comrehense how signals between an oscillator and the chip are going, what are they, what are the restrictions on them and how to connect in between flawlessly.
Hi Bean,
I was thinking a while and realized I didn't understand what was wrong in your case - two almost equal external sources, propeller hanged up sometimes.
Could you elaborate?
Wow! How can I miss it! ((
Excellent idea in the scope of the topic - but I'm still not an electronic engineer and not a guru in propeller's abilities.
abecedarian, I would be happy if anyone in charge of knowledge confirmed your solution.
Nevertheless, I've thrown the idea to think the thought of switching oscillators [this idea was dead from the entry as I now understood] and just starting to go thinking around your idea.
Thanks a lot! I suspect you'll free a lot of minds from my stupid problem ))
BTW, abecedian, you know - if your idea works it should resolve all the problems with different video-drivers! Could you check it? [My Propellers & boards are still in delivery]
Best regards, Vladislav
The runt pulse can violate the Prop's timing requirements and cause it to hang.
Sorry, Phil - the image isn't accessible from my side ((
Nevertheless - could you please expand the abecedarian's idea to use external PROGRAMMABLE clock generator?
Bean
Phil, thank you!
But the idea is to switch clock frequence "softly", let me re-post early thougts:
Ok, lets's imagine an algorithm:
Would it work?
If I understand correctly, a runt pulse will appear to happen anyway if we change input frequency anyhow.
Is there a decision to resolve the problem? Or the frequencies are fixed for us forever? Is it our limit with Propeller?
1. what are the consequences of changing from an internal clock to the external? I thought it is Ok by the manual.
2. if Ok, then what or who can stop me from establishing my frequency (XTAL+PLL) ?
2a - where is here their runt pulse?
3. if Ok, then what or who can stop me from establishing my frequency back to internal?
4. Now I want to switch back to external frequency - You say it can be a runt pulse...
Ok, lets think of external PLL to avoid runts!
How is the schema of a Phase Locked Loop (PLL) connected between PX8 and DS1077 should looks about?
Hope it will cost of a tiny chip and a couple of resistors and condensators.
Just a question - at what frequences (discrete or continuous) the Propeller works?
The manual says AFAIK about boundary values.
Does Propeller work at any frequency inside the boundaries?
If no, what is about precize values in between known boundaries?
