Rocket Launches Into Space, Then Returns to Launch Pad
Just saw this and found it interesting. Jeff Bezos' Blue Origin rocket launches capsule into space, then returns and lands upright. It looks like it's coming in too hot and will crash, then a sudden burst of thrust slows it waaay down for final touchdown.
Jeff Bezos' rocket lands safely after space flight
As weird as it may sound, that's more exciting than a heavyweight boxing match.
Mark Cuban and Richard Branson are also competing for the prize.
Agreed, it will be fun to watch the Bezos/Musk battle for space.
This was my thought as well.
I think this landing is great, but I agree there's a big difference between "to space" and "in orbit".
I'm also in agreement. It's a lot of fun to see rich people spending money this way.
People have been launching rockets and having them make controlled, verical landings their tail for years. The only difference here is scale. And from the point of view of the first stage booster, it makes little difference if the payload goes into orbit or not.
I personally don't view this as head to head competition, as one is working to help create a functional transportation system, while the other is making a carnival ride.
Is this the same size of a booster used for orbital flights? If so, then I mostly agree.
Hello!
According to his (Bezos) plans include it. However they are not flight rated, which means the booster is only traveling to the limits of our atmosphere, and then returns like that. Eventually they will be making plans to participate in the same program as the Space-X program.
Erco? What's your robot doing in his yard throwing early snowballs at the passing cars?
SpaceX recently won a contract from NASA to ferry astronauts to the ISS around the end of 2017.
Based on this video, that doesn't seem quite right. I'm just guessing, but from this it looks like they have adequate throttle control and can descend with one engine running.
My understanding is that the weight of an almost empty booster after a launch is less than the minimum thrust of one engine, which means that it cannot hover. The booster must land using a "hover-slam" method, where the velocity must be decreased to zero at the time it reaches the ground without hovering.
SpaceX is working on a new engine called Raptor, which will have a wider throttle range. The Raptor engine may allow hovering. Of course, hovering requires even more fuel, so there are limits on how long the rocket can hover.
My understanding is that the fuel used for landing is the extra fuel that is used to provide a margin of error for launching. As long as the launch is nominal there will be fuel left over. If the launch required more fuel for a launch due to a mechanical issue there would be nothing left for landing. Adding the capability to hover will require more fuel, reduce the payload weight or reduce the altitude that can be achieved. In the end, it would cost more to hover, and it would reduce the benefit of having a reusable booster.
Landing rockets sci-fi style is still pretty cool.
X PRIZE Cup 2007 - Northrop Grumman Lunar Lander Challenge
It becomes much more difficult to make a vertical landing when there is wind. Not only must the vertical velocity be close to zero at touchdown, but the horizontal velocity must be zero as well, and the rocket must be vertical while trying to hit a bullseye on the ground. For a rocket to counter the force of the wind using a gimballed engine it must be pointed slightly into the wind. Of course, this means that the rocket is not vertical.
So the only way a rocket can have zero velocity and be vertical at touchdown is for it to fly into the wind with enough velocity so that by the time it goes back to vertical it's horizontal velocity reaches zero. This becomes even harder if the wind is gusty.
I'll research the SpaceX engine design because then I'll want to know "Does the ISS stay within the magnetosphere? "How fast does the ISS travel?"
As for the ISS, yes, stays within the magnetosphere, and the ISS travels at the speed anything in its orbit would travel. In round figures, something like 17,000 mph. Maybe someone here knows more about the magnetosphere than I do (which isn't much), but in general the ISS is protected from the worst of cosmic radiation if that's what you're thinking about. There is the South Atlantic Anomaly which is a region where one of the Van Allen belts is lower and anything passing through that, including the ISS, does experience some additional radiation. Anyone up to speed on the details?
Actually, I would like to see a base set up on the moon, built by robots. I think it would help in communications and make it possible to launch and return from Mars. I hope these guys succeed because it would make a lunar base a plausible goal.
@lardom, I agree that we need to set up a base on the Moon first. It only takes three days to travel to the Moon, whereas a trip to Mars takes seven months. A Mars trip can only be done every 26 months when it is closest to the Earth. A Moon trip can be done at any time. A lunar mission only requires packing a week's worth of food and other resources. A Mars mission requires packing over a year's worth of food. And then there's the exposure to weightlessness and radiation for an extended period of time.
On top of all of that we still have hope of finding life on Mars. The last thing we'd want to do is have the potential of exposing Mars to Earth-borne bacteria from manned missions until we thoroughly explored it using unmanned equipment.
Go to http://www.spacex.com/webcast/ and advance the video to 32:23.
Check out the neat 9 minute time exposure photo of the launch and return at the beginning of this article.
http://arstechnica.com/science/2015/12/by-making-a-historic-landing-spacex-launches-new-age-of-spaceflight/
What is amazing is that they turned around a rocket that was going 3,700 mph, 45 miles high (not in space), a hundred miles downrange* and returned it to land where it started out.
* I don't actually know how far downrange it went but going downrange is what really sets it apart from what Blue Origin did a short time ago.
