Split 12 bit number into two separate bytes for data transmission - then put them back together
in Propeller 1
Hello,
I have a 12 bit number (0 to 4095) that I need to transmit through RF. The RF module I am using (nRF24L01) transmits data on a per byte.
I was wondering if there was an elegant way to convert a 12 bit number into two separate bytes, load them into the payload byte array, then transmit?
Then on the other side I receive this array of bytes, and I re-assemble these 2 bytes back into the original 12 bit number?
Thanks and any help/advice is greatly appreciated!
EDIT:
I am imagining I would have 2 variables:
The original number is currently being stored in a long... I suppose it could also be stored in a word.
So it seems I need to shift the long over 16 times, and collect these bits and store them in part1. Then the remainder would be part2. Is this correct?
EDIT:
VAR
Byte part1
Byte part2
And on the other side:
If the values you're sending could be negative and still fit into 16 bits, you can do this on the receiving end (if your receiving values are longs [should be for signed values]):
This is basic shifting & masking, but you may want to think about how to spread those two halves.
8bits in one byte plus 4 in the next is simple, but that gives no protection against reverse order from dropped bytes in Txmit, so you may want to pack as 6 data bits per byte, and use one of the 2 spare bits to signal HI/LO halves.
That leaves one more bit as a user flag :
eg Bytes as
[00_Data6] = Low 6b
[01_Data6] = High 6b
[1_Data7] = Spare user 7b
Thanks a lot for these snippets this was exactly what I was looking for! I did not realize the syntax existed for the ".byte[x]" thats pretty useful!
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ Debug : "FullDuplexSerialPlus" PUB largeByteValue | offset_var, value_holder, idx Debug.start(31, 30, 0, 57600) waitcnt(clkfreq * 2 + cnt) value_holder := 180000 repeat idx from 0 to 3 byte[@offset_var][idx] += byte[@value_holder][idx] debug.dec(offset_var) Debug.tx(13) debug.bin(offset_var, 32) Debug.tx(13) waitcnt(clkfreq+cnt)If you're curious I'll zip my PTX and PRX for you to try. I want to control motors so I decided it would be quicker to transmit an 8 bit value and scale it on the PRX side
