ABS doesn't set the carry bit — Parallax Forums
On the P2 the ABS instruction doesn't set the carry bit like it does on P1 when the source value is negative. It would be useful if the ABS instruction worked the same on the P2.
    Dave, thanks for finding this. I just fixed it. It will be in the next release.
  • Good catch! My unit test also had this wrong. *sigh* That always makes me wonder what other ones are wrong...
    (note: There are a number of other P1<->P2 differences that we *do* know about.)
    Among all the negating/NOT'ing instructions in that group, it was the only one that should have returned S[31], instead of the MSB of the negate/NOT.
  • cgracey wrote: »
    Seriously? It's 4am there! Do you ever sleep? Or is this like the fairy tale shoemaker... elves take over at night, and each morning the chipmaker wakes up to discover that several new instructions have been implemented.
    Well, I'm tired and not being very productive. I should go to bed.
    I've been working on the smart pin circuit. It's hard to believe that when this part is done, the chip is basically done. We will need to test it for a while, though.
  • cgracey wrote: »
    Agreed. Now, go to bed! I'd rather you get more rest, take a little longer to finish the pins, and get it right the first time. Fewer bugs up front will save time in the long run!
    Okay. I'm going. Thanks for your input.
  • @Chip, thanks for fixing this so quickly.
    @Seairth, could you post your unit test program? I'd like to run it under spinsim to see if it catches anything.
  • Dave Hein wrote: »
    https://github.com/Seairth/P2UnitTests
    Currently, each instruction is a separate unit test. It's a little tedious to test. At some point, I intend to consolidate these and switch the results output to serial. See the wiki for additional details. (I've also updated ABS to correct the two tests related to your discovery.)
  • Thanks, that looks good.
  • evanhevanh Posts: 17,161
    Hmm, going by what I see in Seairth's unit tests, I don't think I'm happy with RCL and RCR. I'm not seeing any wrap-around, they appear to be acting more like SAL and SAR respectively.
    evanh wrote: »
    ROR/ROL are the ones that wrap.
  • cgracey wrote: »
    evanh wrote: »
    If RCL and RCR don't "rotate", should they be called SCL and SCR?
    David Betz wrote: »
    evanh wrote: »
    Maybe those names would be more appropriate.
  • jmgjmg Posts: 15,200
    Do they include the CY ?
    jmg wrote: »
    Only as output. The bits rotate within the long.
