A-to-D sampling of the Nissan leaf battery.
The Nissan leaf batteries have three terminals. Referenced from the center terminal the voltages when fully charged read +4.2 volts and -4.2 volts respectively. I want to read both cells and feed the results into a Propeller. I'm aware that a MCP3208 could read the +4.2 volts but what would be the easiest way to get the -4.02 into the uP.
I've used this method to read voltage from a shunt that can be +/- with an MCP3304. While it does reduce your resolution, you can raise it again with oversampling/decimation if need be.
I've over simplified this. With 12 cells I'll need 24 channels of sampling. I notice the MCP3208 has a single digital ground for each of my three chips. I don't have experience with the MCP3304 but suspect it may be a better candidate for the application. During pack bottom balancing resolution is not an issue. During long term monitoring after to detect soft shorts resolution might be more of an issue.
As far as I know, the only difference between the chips is one bit of resolution, but I haven't used the 3208. Plenty of others have, and there is extensive support for it in the OBEX; while I don't think there are drivers there for the 3304, I have a simple 30-line subroutine in PASM that reads it, including oversampling/decimation. It requires 88+ MHz to sample at 100ksps (2 MHz SPI); since I use it at 3.3V, at which it's only good for 50ksps (1 MHz SPI), it can do that at 44 MHz or greater.
As long as you don't need speed, the resolution thing is pretty solvable; by oversampling 1024 times, I get 16 bits of resolution with the 3304 from a shunt that only reads +/- 0.1 V, so you should be able to get 16+ bits with the 3208 reading at +/- 0.3V. Using a 0.5 V voltage reference (the minimum that the 3304 supports) helps.
