Will PropScope run on a Windows Surface?
                    I'm very impressed with both the hardware and software so far; the display looks great on my 17" Win7 laptop, but ....
As a bench tool, it would be great if PropScope would run on a Windows Surface that I had laying around from another project. I downloaded the software and USB drivers, but they wouldn't install.
I got an error message something like "This software will not run on this computer."
-doug-
-doug-
So it's possible but probably not worth finding out unless you have experience with the emulator or are feeling very adventurous.
Is there ANY tablet computer that will run PropScope software? It would be especially nice if the touch-screen worked.
-doug-
Other options would be something like the ASUS transformer or one of the "all in one" desktops where everything is built in to the monitor.
I have the T200 and it's pretty impressive. I've been doing my P2 testing on it and running other tools that are windows only. It has 4GB of memory, 64GB of storage (C: drive) a micro-SD slot you can use for a
I haven't tried it with my Propscope, so I can't attest to that working with the touch screen or not.
John Abshier
These things really are tough and feature a tilt/swivel screen that turns them into a - albeit bulky - tablet.
Mine came with fresh installs of XP and fully functional, including the touchscreens. I drag them around factory floors and have never felt so comfortable. IIRC, I got mine for ~$150 or something.
I would expect there are many.
See this thread
http://forums.parallax.com/discussion/158242/cheapest-windows-based-propeller-dev-platform-found-at-office-max
The HP stream mentioned runs (ran) 32b Windows, 8.x and the COM support seems just fine on what I've tested.
It does need a HUB to power both the tablet and target.
ie just find an x86 tablet, with 32b Windows.
The Stream 7 and the iCraig tablet are both 32-bit though, because they come with only 1Gig of RAM. The iCraig also has a separate full size USB port so you don't need a hub or OTG cable. Both tablets have run every single Windows XP era application I have thrown at them without difficulty.
https://www.parallax.com/downloads/propscope-usb-oscilloscope-software
version 207 work great on the HP Stream7 which is a 32Bit machine.
PropScope software works, but there will be a battery issue, as the scope takes up the only usb port. No charging while usins the scope, but I think people have found splitters.
The iCraig tablet has a separate USB port as well as micro-HDMI which IMO makes it much more useful, despite being not as well made. It has the same 32-bit software as the Stream 7. I have a lot of stuff that doesn't run on any 64-bit OS but works on these tablets.
If you've verified that PropScope works on any 64-bit WinOS then it should work on all of them, which means all the tablets including the Surface should work. But in addition to being 32-bit the Stream and iCraig are way cheap at around $100. You'll need a Bluetooth mouse and keyboard (maybe even for the iCraig, even though it comes with a keyboard folio it's meh) but even with all the goodies lots cheaper than even a netbook was back when they were a thing.
