Choices for the PLLDIV value...
I was looking through some video drivers to see how they worked.
In one example (a TMS9918 type driver), the FRQA was set to 2 * ColorBurst and the PLLDIV mode set to VCO/2. So that comes out to 16 * ColorBurst.
However, in another driver (a ULA type driver) the FRQA was set to ColorBurst and the PLLDIV mode set to VCO/1. Which translates to the same value.
So both frequencies are equal from what I understand.
My question is, why use one over the other? Is it just personal preference or do you think there was a reason?
If it helps any, the TMS driver is a 4 color driver whereas the ULA is a 2 color.
Thanks.
Thanks.
Bean
That does make sense.
Thanks.
