Are we already at 80Mhz on the A9 123 board? — Parallax Forums
Just got setup. Thanks Chip and Parallax. This one looks like it works great.
Ran my test code, and got what looks like a mess on the screen. On a guess, I tried 80Mhz as the base for the timing calcs, and it all appears to work just fine.
  • Yep, 16 cogs @ 80 MHz = :):):)
  • Whoopee!!
    I'm unclear on the DAC differences. NTSC signal appearing on all DAC connectors. I'm not sure my DE2 did that. Never got my A7 to work, so I can't compare.
  • That's right for all the Dac's to show the signal.
    From the docs streamer modes
    dddd
    1111 X3 X2 X1 X0 output X3, X2, X1, X0 on all four DAC channels
  • cgraceycgracey Posts: 14,293
    edited 2015-11-27 05:40
    On the latest compiles, DAC channel 0 does not go out to a DAC, but its LSB goes out digitally as the HSYNC signal on the VGA connector. DAC channels 3/2/1 are R/G/B.
    edited 2015-11-27 07:10
    I just found that out by changing modes. Mode %0100 results in only the sync being displayed. No signal, no borders, etc... neat!
    Hey, I'm having trouble understanding how to calculate xfr values.
    This: f_color / f_clock * float($7FFF_FFFF) * 2.0
    What is "float($7fff_ffff)" Is this a floating point hack for a shift operation?
    I'm wanting to do some scaled integer math to compute signal timings...
    Basically, I want to put this stuff into Excel, figure out the math, then do PASM to get away from the constants. Did the same thing on P1 to validate a lot of signals.
  • ok guys, how do I get me one of these A9 boards?
    potatohead wrote: »
    I was trying to mutiply by $1_0000_0000
  • evanhevanh Posts: 17,105
    You've probably already got an answer but the original announce was here - http://forums.parallax.com/discussion/comment/1355129/#Comment_1355129
    I think the A9 boards went out to the people who bought A7 boards. The idea was to swap out all of the A7 boards for A9 boards. I suppose the A9 boards are probably for sale as well, maybe for the same $375 that the A7 boards sold for.
