HoverFly Update Client
Good day everyone, I am having troubles with the "HoverFly Update Client and HoverFly Setup utility" program. They show up in my Program and features, but when I look in "File Explorer" they are no where to be had. I look in the Program Files folder and Program Files (X86) Folder. I am running Windows 8.1. Will the software run in Windows 8.1? and if not how do I arm my HoverFly Open FC? I also downloaded the Parallax-USB-Drivers-v2.10.00 and installed the drivers, but that doesn't show in the drivers of File Explorer. Could I get some help!!!! please? , help I need somebody, help just not anybody! Thank you for your time folks.
If I do a search for "programs and files", it just brings up the shortcut.
The program works under Win7 PRO, so it should work under 8.1.
Make sure you select HF Open, then "X" mode on the next page.
I just installed Hoverfly Update Client to my Win 8.1 HP Stream. Works flawlessly.
You may want to uninstall the FTDI drivers (USB), and the Hoverfly software, the re-install everything. I think the Hoverfly installation comes with the FTDI drivers for the HoverFly board, (although they should be the same from Parallax).
Under the Driver tab, you should see the FTDI and Version Number.
