onewire-Bus over a wire 75feet long - what can I do to improve signal-quality
StefanL38
Hi,
after a long time of abstinence I'm back on prop-coding.
I want to install a temperature control for room heating.
The sensors work in VDD-supply-mode ground Data and Vdd connected.
For sensing the temperature in the rooms I want to use onewire-sensors DS18S20 (9bit resolution) or DS18B20 (12bit resolution)
In my pretests on the workbench I connected some 18S20 and some 18B20 together and all worked well.
As long as I connect the sensors through short wires aprox 3feet long all works well.
In a test with a single DS18S20 over a wire 75feet long worked to.
But as I added a seconds one I got strange results.
instead of two sensors six sensors were scanned. two times "three" sensors with the same Sensor-ID.
Is this some kind of signal reflection on the long wire?
How can I improve signal-quality? Or is a cable 75feet long just too long for the specifications of a onewire-bus?
Any kinds of hints and tips are very much appreciated.
best regards
Stefan
Edit: by the way where have all the options about receive email or message if somebody answered gone?
best regards
Stefan
A last minute idea: try to leave a long coil of cable at the end of the line - at least 100m.
Erlend
thank you very much for your suggestions. At the moment I'm busy with redrawing the DXF-File of the
MeArm V1.0 robotarm. I want to mill them out of plywood to bring it tomorrow to my students at school.
If I have finished this and if I have mounted the ventilationducts in bathroom and toilet
I will test your suggestions.
best regards
Stefan
P.S. lol cool bottomline :-))
this is a good idea. Thank you.
Will do that.
best regards
Stefan
