Capacitor Help
NWCCTV
I am in need of a Capacitor replacement for a cap that is marked CS 100 50V. I have tons of capacitors but they are all uf. What can I use as a replacement?
All might help us determine what it is.
100 farads would equal 100,000uf right? It would be a rather large capacitor.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.X100000uf+50+volts.TRS0&_nkw=10000
Or it could be 100 picofarad... very tiny.
http://www.ebay.com/itm/E-Projects-100pF-Ceramic-Disc-Capacitor-50-Volts-25-Pieces-/171173389373
What is it supposed to do?
So at 100 Farads at 50VDC you would require an extremely large capacitor.
Isn't there some production labling convention for capacitors that claims a value without any additional code is microfarads?
The real core issue is that without a good schematic or testing a similar capacitor in good working order, nobody can be sure. If you removed a damaged one, there is no point in testing it. You would have to pull another one exactly the same and presume it to be in good working order -- then test that one.
... a 101 would be 100uF , but since this is a 100 , I suspect that it might be 10uF
No, I think it's 10uF .... the link below is just a reference after a Google search for "cs series capacitor" ... it is close, but not exact, but something to notice is that the capacitors are referenced in uF and not pF ... after a certain point or style of capacitor (perhaps just being an electrolytic) it should be obvious that your values are in uF and not pF ... notice the chart also for both "CS series" and "PZ series" ... both are in uF
http://www.mouser.com/pdfdocs/Nichicon_CSseriesCaps.pdf
http://www.jbcapacitors.com/pdf/JCS-2000H-at-85-SMD-Aluminum-Electrolytic-Capacitor.pdf
