Aerobatic Quadcopters
LoopyByteloose
Simply put....
Can you take off, invert your quadcopter in flight, and continue on?
And finally, can you return to a normal flight and land safely?
https://forums.openpilot.org/topic/8791-quadcopter-aerobatics-what-can-be-done/
http://oddcopter.com/2012/11/27/quadcopter-aerobatics-in-slow-motion-by-warthox/
Flying a quad 'inverted' is beyond me. I had to work hard at controlling my copters with the nose facing me. It meant thinking magnetically as in 'attraction' and 'repulsion'.
http://www.rchelicopterfun.com/3d-quadcopter.html
Basically, you run it like a heli, with the throttle in the center position. Push up, it goes up. Invert, push down, it goes up. Now your mind is doing two thing, is it going away or toward me, am I upright or upside down?
I do it on a simulator first.
