Pnut bug with REP and AUGS
in Propeller 2
Hi Chip
I've encountered a bug in Pnut that icorrectly encodes the REP instruction block length when the immediate value is > 9 bits. (AUGS applied)
Here's the sample code source
Brian
orgh $12000 org rep @rblk1,#511 add myreg1,myreg2 wz if_z sub myreg1,myreg2 wc if_nc xor myreg1,myreg2 wz,wc rblk1 rep @rblk2,##512 '<-- Repeat block length +1 error add myreg1,myreg2 wz if_z sub myreg1,myreg2 wc if_nc xor myreg1,myreg2 wz,wc rblk2 mov myreg3,##512 rep @rblk3,myreg3 add myreg1,myreg2 wz if_z sub myreg1,myreg2 wc if_nc xor myreg1,myreg2 wz,wc rblk3Here's is my disassembly of Pnut's output
Propeller 2 - Disassembler V1.02 - Ozpropdev 2015 ------------------------------------------------- 12000: $FCDC05FF %1111_1100110_111_000000010_111111111 REP #$2,#INB 12004: $F10A0302 %1111_0001000_010_100000001_100000010 ADD $101,$102 WZ 12008: $A1920302 %1010_0001100_100_100000001_100000010 IF_Z SUB $101,$102 WC 1200C: $357A0302 %0011_0101011_110_100000001_100000010 IF_NC XOR $101,$102 WZ, WC 12010: $FF000001 %1111_1111000_000_000000000_000000001 AUGS #$1 (##200) 12014: $FCDC0600 %1111_1100110_111_000000011_000000000 REP #$3,#$0 '<-- should be REP #$2,@#0 12018: $F10A0302 %1111_0001000_010_100000001_100000010 ADD $101,$102 WZ 1201C: $A1920302 %1010_0001100_100_100000001_100000010 IF_Z SUB $101,$102 WC 12020: $357A0302 %0011_0101011_110_100000001_100000010 IF_NC XOR $101,$102 WZ, WC 12024: $FF000001 %1111_1111000_000_000000000_000000001 AUGS #$1 (##200) 12028: $F6060600 %1111_0110000_001_100000011_000000000 MOV $103,#$0 1202C: $FCD80503 %1111_1100110_110_000000010_100000011 REP #$2,$103 12030: $F10A0302 %1111_0001000_010_100000001_100000010 ADD $101,$102 WZ 12034: $A1920302 %1010_0001100_100_100000001_100000010 IF_Z SUB $101,$102 WC 12038: $357A0302 %0011_0101011_110_100000001_100000010 IF_NC XOR $101,$102 WZ, WCCheers
Brian
