Simple NTSC Text Driver — Parallax Forums
ozpropdevozpropdev Posts: 2,793
edited 2015-11-11 04:47 in Propeller 2
Update: Now supports 8x16,16x16 and 16x32 size fonts.
See here
Hi All
Here's a quick and dirty NTSC text driver based on Chip's NTSC demo.
It produces 12 lines of 16 characters and uses just 1 cog.
Ascii data in hub space is converted to pixel data during the 192 line field loop.
The demo shows 10 cogs modifying hub ram simultaneously.
I found it useful as I am using all the leds on the A7/DE2 boards and serial so being able to get additional debug data was handy.
I cheated and use the color pallete from Chip's bitmap :)
  • Nice one ozpropdev :D
  • Nice!
    Having text to gawk at sure helps!
  • I like that!
    What size monitor/tv, looks around 10" - 12" comparing screen size to connector size?
    I will have to look for the appropriate connectors and a cable, which are safely stored ... somewhere ... to use the other cog in by bare-board Nano setup.
  • @78rpm
    Yep a 12 inch monitor.
    Sadly the NTSC driver doesn't fit the nano. The frame buffer is 49.1k and then theres the font data on top of that.
  • @ozpropdev
    Shame. Bigger fpga needed obviously, unless it is possible to have the frame buffer ASCII chars only and convert on the fly, in a similar manner to the hi-res VGA on P1?
  • That's looking mighty useful!
  • I am already stumbling at the first lines of code:
                    rep     @cogz,#10       'launch 10 cogs
                    coginit #16,##@testcode
    cogz
    doesn't that start the same cog 10 times?
    confused!
    edited 2015-11-11 02:18
    #16 tells cognitive to start the next available cog
    Cognitive. ... thanks, autocorrect!! :)
  • mindrobots wrote: »
    ahh - I missed that one...
  • I made a few tweaks to the driver and it now supports 8x16,16x16 and 16x32 font sizes.
    2285 x 1713 - 1M
  • cgraceycgracey Posts: 14,289
    edited 2015-11-11 04:32
    Having a video display is great for testing. I've been limited to a 16 channel logic analyzer, so far.
  • jmgjmg Posts: 15,200
    You could claim that adding this actually shortened the critical path, due to higher testing productivity ;)
  • jmg wrote: »
    That's one reason I started to put together the software test harness I've been using. It makes it so much easier to see inside.
    I got the streamer docs done! They could stand some improvement, but I think I got all the details in there.
  • Looks great Chip.
    I'm doing simple 2 color right now. Was nice to have the mode bits. :)
    potatohead wrote: »
    Looks great Chip.
    Great! It would be good if people wound up trying all the modes.
    I'll work on the colorspace converter documentation tomorrow.
  • Well, the 1, 2, and 4 bits all do what they say.
