Powering BOE with 6 AA batteries
in BASIC Stamp
My son is working on a robotics project for school. He's going to use continuous drive servos to drive the robot. Originally, we were going to just have a second set of AA batteries to power the servos independently of the BOE's 9v power supply but a closer look at the rules revealed that this is not allowed. It's either a single 9v battery or a set of AAs. Concerned that the single 9V won't be enough to power two servos reliably or, at best, if it does I'll go broke buying 9v batteries.
So, the thought now it so get a 6x AA battery older and connect it with a 9v clip to the BOE. My question here is will higher mAh rating of the AAs harm the BOE or BS2 or will be OK? I know there servos can have a spike in the amps the draw when the start up. It would be nice if we can just power the servos off of the Vin source on the BOE but if the higher current draw might be to much, it would be easy enough to splice a couple of leads off the battery to power the servos directly from the battery pack.
My biggest concern is frying the BOE by plugging 6 AA batteries in instead of a single 9v.
6AA will not fry a BOE board. Let's see some pics and videos!
The BOE will run off a 9V power source, but it works best with 6-7.5V. Anything over that is just dissipated as heat. Servos work best from around 4.5V to 6V. You can run them off Vdd (5V), but that adds to the heat dissipation.
If you want to use rechargable AA cells, use 5 since they're 1.2V instead of the 1.5V of alkalines. 5 x 1.2 = 6! There are battery holders for 5 cells, but this won't fit in the space provided in the BoeBot's chassis if that's what you're using. You can get a holder for a single cell and glue it to the back top of the chassis then wire the two battery holders together in series.
A 4-cell battery holder is included with the Boe-Bot robot kit, and can be installed according to the directions in the kit documentation (if using our small robot chassis). A 5-cell battery holder will fit as well, if installed in the orientation shown in the documentation for the ActivityBot robot (again, only if using our small robot chassis).
We're not using the Boe-Bot kit, the rules of the contest require it to be a bit more scratch built. Straight line speed of the robot is a factor so the thought was to run the high speed servos at 9v to eek out a little more speed. I had done some other Googling to indicate servos could handle a bit more voltage than what they are rated for. But, maybe a 5 cell pack is a little better option as it won't shorten the life of the servos.
AAs should be sufficient as the test runs for the contest will be very short. He doesn't need it to run for an extended period of time.
What you need to do is to research the absolute maximum voltage acceptible for your continous rotation servos and let that define your power design. Many will take 7.4VDC that two lithium ion 3.7VDC cells provide. And the Homework board will do fine with the 7.4VDC as well.
Another alternative is NiCad battery packs that are rechargible. They come bundled in a variety of combinations that might work well.
AA batteries are fine for our needs. Cheap and effective.
_mike
The motor itself may easily tolerate 9VDC or more. But each manufacture adds a board that may have much lower voltage limits. If you do burn out a board, it can be removed and the servo can be adapted to be driven externally with an H-bridge... maybe at a higher voltage.
