Homemade hardwood floor / laminate floor sweeping robot
in Robotics
So this is something I would like to give a shot using the Prop. Basically the cheapest I can make this thing, the better. I am thinking about getting one of those roller brooms and attaching a robot to one to push it around. Sounds pretty simple to me so I want to start by thinking it all the way through before I move too fast. As of right now, I am thinking about how to charge this thing automatically. Maybe some kind of IR guided dock station....
So, should I use a ultrasonic ping sensor on a fixed position or would this bother my dog? I need this to detect objects accurately so it is a fool proof design. Don't want it getting stuck under the couch for hours while we are away. Any ideas or pointers?
Put a conductive strips at 90 degrees to each other a corner. Robot drives forward into the corner and contacts along each side of the robot touch the conductive strips. If needed a sensor or switch turns on power when the robot is present. Simple and reliable.
It is very wise to think it through a bit before starting , every minute you spend planning saves multiple hours in fixing later.
Consider the Neato robotic design https://www.neatorobotics.com/ These things are awesome but cost $500. We should be able to build these from parts for under $100. Maybe less if its a sweeper rather than a vacuum. This might be a good high level requirements target. If you only get half way it would still be awesome.
These run a very efficient and thorough grid pattern, and have excellent obstacle avoidance.
I believe they use a two point positioning system (the local radio thing), and a laser distance sensor on the bot to measure the room. The lasers I have are probably 10x overkill for a sweeper, but I don't know off cheaper solutions off hand.
I don't think the ping would bother your dog, she could hear it (I can even hear it when by head is directly in front of it), but it doesn't make us crazy.
Consider using IR LEDs and photo detector as proximity sensor rather than actual bump sensors. The guys in the robot club have good success with IR, and bumping looks clumsy.
If you start with mobile part first, and add the sweeper part AFTER you have navigation down, you can use the really cheap Uln2003 Stepper Motor Drive driver and the 28BYJ stepper, these are extremely cheap and slow. Once you get a bot with these to navigate, you can upgrade as needed to something fancy.
I just ordered a pair of nrf24L01 modules. I plan to put a pan-tilt camera on it this time.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PING_Pin = 0 ' I/O Pin For PING))) LED_Pin = 1 _SensorServoPin = 2 _rightServoPin = 3 DEBUG_BAUD = 9_600 Sensor_Servo_Steps = 1_990 _timeStepInMilliseconds = 5 _updateFrequencyInHertz = 50 VAR LONG range LONG Ping_Servo_control[200] LONG Ping_Servo_Angle OBJ Pst : "Parallax Serial Terminal" ping : "ping" ser : "PWM2C_SEREngine.spin" PUB Start Pst.Start(DEBUG_BAUD) ' 1 cog cognew(move_ping_servo, @Ping_Servo_control) ' 2 cogs pause(100) dira[LED_Pin]~~ repeat ' Repeat Forever range := ping.Inches(PING_Pin) ' Get Range In Inches Pst.dec(range) ' Print Inches Pst.str(string(" - Angle : ")) Pst.dec(Ping_Servo_Angle) Pst.str(String(13)) if(range < 10) outa[LED_Pin] := 1 else outa[LED_Pin] := 0 pause(1) PUB move_ping_servo | frequencyCounter ifnot(ser.SEREngineStart(_SensorServoPin, -1, _updateFrequencyInHertz)) reboot ser.leftPulseLength(200 + 0) pause(1000) Ping_Servo_Angle := 0 repeat repeat frequencyCounter from 0 to Sensor_Servo_Steps step 10 ser.leftPulseLength(200 + frequencyCounter) Ping_Servo_Angle := (((frequencyCounter * 100) / Sensor_Servo_Steps) * 18) / 10 pause(_timeStepInMilliseconds) pause(200) repeat frequencyCounter from Sensor_Servo_Steps to 0 step 10 ser.leftPulseLength(200 + frequencyCounter) Ping_Servo_Angle := (((frequencyCounter * 100) / Sensor_Servo_Steps) * 18) / 10 pause(_timeStepInMilliseconds) pause(200) PUB pause(Duration) if(Duration > 0) waitcnt((clkfreq / 1_000 * Duration) + cnt) returnThe servo I am using is an old Futaba FP-S148 that came from one of my old planes.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PING_Pin = 0 ' I/O Pin For PING))) LED_Pin = 1 _SensorServoPin = 2 Left_Motor_Pin = 3 Right_Motor_Pin = 4 DEBUG_BAUD = 9_600 Sensor_Servo_Steps = 2_000 _timeStepInMilliseconds = 7 _updateFrequencyInHertz = 50 Stop_Val = 1470 Left_Full_Speed = 1300 Limit_Speed_Range = 200 VAR LONG range LONG Ping_Servo_control[200] LONG Move_Servo_control[200] LONG Ping_Servo_Angle LONG Travel_Speed BYTE Direction OBJ Pst : "Parallax Serial Terminal" ping : "ping" ser : "PWM2C_SEREngine.spin" steer_left : "pwmAsm.spin" PUB Start | shortest_range, loop_count, last_angle Pst.Start(DEBUG_BAUD) ' 1 cog cognew(move_ping_servo, @Ping_Servo_control) ' 2 cogs pause(100) cognew(move_bot, @Move_Servo_control) ' 2 cogs dira[LED_Pin]~~ loop_count := 0 shortest_range := Limit_Speed_Range repeat ' Repeat Forever range := ping.Inches(PING_Pin) ' Get Range In Inches Pst.dec(range) ' Print Inches Pst.str(string(" - Angle : ")) Pst.dec(Ping_Servo_Angle) Pst.str(String(13)) Pst.dec(Travel_Speed) Pst.str(String(13)) if loop_count => 4 shortest_range := shortest_range + 5 if shortest_range => Limit_Speed_Range shortest_range := Limit_Speed_Range loop_count := 0 case Ping_Servo_Angle 0..30: ' Objects in 30 deg range last_angle := 0 31..60: ' Objects in 60 deg range last_angle := 1 61..90: ' Objects in front left if range =< shortest_range shortest_range := range if last_angle == 1 OR last_angle == 3 last_angle := 2 loop_count++ 91..120: ' Objects in front right if range =< shortest_range shortest_range := range last_angle := 3 121..150: ' Objects in 150 deg range last_angle := 4 151..180: ' Objects in 180 deg range last_angle := 5 OTHER: Travel_Speed := Stop_Val + (Left_Full_Speed * ((shortest_range * 100) / Limit_Speed_Range) / 100) if(range < 10) outa[LED_Pin] := 1 else outa[LED_Pin] := 0 pause(10) PUB move_ping_servo | frequencyCounter ifnot(ser.SEREngineStart(_SensorServoPin, -1, _updateFrequencyInHertz)) reboot ser.leftPulseLength(200 + 0) pause(1000) Ping_Servo_Angle := 0 repeat repeat frequencyCounter from 0 to Sensor_Servo_Steps step 20 ser.leftPulseLength(200 + frequencyCounter) Ping_Servo_Angle := (((frequencyCounter * 100) / Sensor_Servo_Steps) * 18) / 10 pause(_timeStepInMilliseconds) pause(100) repeat frequencyCounter from Sensor_Servo_Steps to 0 step 20 ser.leftPulseLength(200 + frequencyCounter) Ping_Servo_Angle := (((frequencyCounter * 100) / Sensor_Servo_Steps) * 18) / 10 pause(_timeStepInMilliseconds) pause(100) PUB move_bot dira[Left_Motor_Pin]~~ outa[Left_Motor_Pin] := 0 Travel_Speed := Stop_Val Direction := 0 ' 0 = Forward, 1 = Reverse pause(1000) repeat outa[Left_Motor_Pin] := 1 pause_ms(Travel_Speed) outa[Left_Motor_Pin] := 0 pause(20) PUB pause(Duration) if(Duration > 0) waitcnt((clkfreq / 1_000 * Duration) + cnt) return PUB pause_ms(Duration) if(Duration > 0) waitcnt((clkfreq / 1_000_000 * Duration) + cnt) returnThe next step is to build the frame for the test bot out of my Erector set parts and hope it fits
