NASA's new methane powered thruster
MikeDYur
Could be a weekend project, how many Propeller's could possibly run this?
https://www.nasa.gov/centers/marshall/news/releases/2015/nasa-tests-methane-powered-engine-components-for-next-generation-landers.html
They are fairly good doing that job, and don't sound that loud as the ones you listed.
Also, they don't compete with humans for food.
Rocket Fuel + Ignition Sorce = Thrust
Three to ten years of living in a tiny tin can and eating a limited menu would be brutal. Yes, we can get a rocket to Pluto and beyond. But riding a rocket so far and so long seems like cruel and unusual punishment.
There are also all the affects of zero or lighter gravity that might permanently cripple you. Space may not be the 'final frontier' so much as the 'final barrier'. Perhaps we might do better by staying home and making an effort to respect each other more.
On earlier dangerous missions, didn't the Russians send a dog or a monkey first to see that it was feasible? A cow or pig might not be such a silly idea for a first live voyager to Mars.
The most obvious thing is to go ahead with a manned moon base, from which you use solar to split water into hydrogen and oxygen. Can it, send out a bunch of refills ahead along the planned route, and get there in weeks instead of forever.
Keep the exotic stuff for tertiary backup case.
It would probably end up being cheaper in the long run, and we'd end up with some moon infrastructure to boot.
Maybe a space station could better harvest atmosphreic moisture as a more abundant source.
Hmm, thats a possibility. However that means:
1 Fuel wasted launching unrefined water vs refined propellant
2. Mars craft will have additional mass for larger and electrolysis manf. and solar panels along entire flight path
3. Safety/risk level. With a lunar base which we need to build at some point anyways, its negligible to shoot out 2x as many needed fuel containers as needed, just in case.
Of course, would be nice if the ISS could obtain water somehow and accomplish this.
