SUBX bug
Seairth
            Peter Jakacki wrote: »BTW, I found a bug with SUBX too, is there one place where we can report these bugs or observations.
I found the (possibly same) bug as well. SUBX seems to be ignoring C.
Here's my test code:
dat
        org
        or      dirb, #$FF
        mov     t1hi, #2        ' 64-bit number: $0000000200000005
        mov     t1lo, #5
        mov     t2hi, #1        ' 64-bit number: $0000000100000006
        mov     t2lo, #6
        sub     t1lo, t2lo wc   ' -> $FFFFFFFF, C -> 1
        setbc   outb, #0
        subx    t1hi, t2hi      ' -> $00000001 (should be $0000000)
        cmp     t1hi, #0 wz
        setbz   outb, #1
loop    jmp #loop
t1hi    long    0
t1lo    long    0
t2hi    long    0
t2lo    long    0
GRN1 should be lighting up, since (2-(1+C)) should be zero. If you change t1hi to #1, then it lights up.
Note: ADDX seems to be fine. I have not yet tested SUBSX or ADDSX.
Edit: changed the code to explicitly test t1hi, since Z is dependent on the prior value of Z for SUBX. Bug still exists.
Yes, it works for all three examples in the P1 truth table.
The > operator in Tachyon uses this and I also confirmed correct operation
