Serial output - Is there a better way to do this?
I'm learning Spin having moved over from PBasic, and I've got one of the inexpensive Catalex MP3 players mentioned in another thread. It works fine with this code:
However, I can't figure out how to represent all the serial commands on a single line. It's easy on the BS2:
What's the best way to do this? I tried out the other commands in FullDuplexSerial but couldn't get them to work. And I've looked through lots of the other serial methods in the OBEX but can't find what I want.
{ Catalex mp3 board sound test 10/17/2015 One MP3 in a folder named 01 on MicroSD card. } CON _clkmode = xtal1 + pll16x ' Crystal and PLL settings. _xinfreq = 5_000_000 ' 5 MHz crystal x 16 = 80 MHz OBJ Serial : "FullDuplexSerial" PUB Go serial.start(2, 3, %0000, 9_600) Serial.Tx($7E) ' Init the Catalex MP3 player Serial.Tx($FF) Serial.Tx($06) Serial.Tx($0C) Serial.Tx($00) Serial.Tx($00) Serial.Tx($00) Serial.Tx($EF) waitcnt(clkfreq + cnt) ' Wait 1 second waitcnt(clkfreq + cnt) ' Wait 1 second Serial.Tx($7E) ' Select TF socket Serial.Tx($FF) Serial.Tx($06) Serial.Tx($09) Serial.Tx($00) Serial.Tx($00) Serial.Tx($02) Serial.Tx($EF) waitcnt(clkfreq + cnt) ' Wait 1 second Serial.Tx($7E) ' Set volume to 15 Serial.Tx($FF) Serial.Tx($06) Serial.Tx($06) Serial.Tx($00) Serial.Tx($00) Serial.Tx($0F) Serial.Tx($EF) waitcnt(clkfreq + cnt) ' Wait 1 second Serial.Tx($7E) ' Play song 1 in folder 1 Serial.Tx($FF) Serial.Tx($06) Serial.Tx($0F) Serial.Tx($00) Serial.Tx($01) Serial.Tx($01) Serial.Tx($EF)
SEROUT MP3, 84, [$7E,$FF,$06,$09,$00,$00,$02,$EF] 'Select TF socket
One way to do it is with byte arrays in a DAT section: As you see, you can also modify the byte data very easy before you send a command.
Andy
Thanks! That was just what I needed. I'm still getting my head around the whole object and method-oriented way of doing things.
FYI, after some experimentation, for anyone else interested in using the Catalex board, the MP3Init sequence is not needed. You just need these:
Then you can select both the MP3 to play and the folder using these commands, as Andy shows above:
Jeff
which thread are you referring? Just curious
http://forums.parallax.com/discussion/161245/erco-here-s-the-cheap-mp3-modules
Since I don't have one and I wanted others to be able to reference the Schmarschmino demos the vendor provides, I used their named constants. Once I get a player and understand what each thing does, I may rename things. Note, too, that all of the demos show no feedback from the player and a baud rate of 9600. This can be done with a single pin and a method; no serial cog is required.
To transmit the example shown for the BS2, do:
txStrEsc( string( $7E, $FF, $06, $09, $7F, $80, $7F, $80, $02, $EF ) )
A $7F is followed by the byte to be sent with its high order bit set. To send $00, use $7F,$80. To send $7F, use $7F,$FF. There's a check for the case where a $7F is the last byte in a string.
Then as Jon suggests, in the application give each function a meaningful name that calls the generic StrN. Or, simply give each string a name that reveals its function.
I didn't think it was necessary to stick the bytes into a buffer before sending -- at 9600 baud a few microseconds here and there between bytes should be fine.
That demo commands disable response from the device so I kept it to one pin. Since coms is the very tame speed of 9600 baud, I was able to borrow (with some clean-up) serial output from Simple Serial.
I set up six buttons as the schematic in the original file here in the OBEX shows. Those aren't shown below because some characters don't display properly in the forum.
