Software Mutex in SPIN
Thought I'd toss this against the wall and see if it sticks.
Requires 15 bytes allocated per mutex for 8 clients (one client per cog), max 128 clients is possible (a whopping 255 bytes per mutex) for those doing time-slicing.
Unfortunately, one cannot really "try" the lock without actually locking, as testing takes many cycles. It could be added though.
I know all this can be optimized further.
Note to self: I need to code, or find, a tiny & efficient heap allocator.
EDIT: Just realized I had the wrong license. Meant MIT (corrected).
mutex.spin
Author: Andrew E. Mileski <andrewm@isoar.ca>
License: MIT
Version: 0.1
The following SPIN code allows for up to 128 clients per mutex.
Each mutex requires 2 * clients - 1 bytes of memory.
Clients must be manually assigned a unique consecutive numeric ID from 0 to 127.
Mutexes are referred-to by address, so that they can be accessed across cogs.
Filter algorithm: Peterson's algorithm for N processes
http://en.wikipedia.org/wiki/Peterson%27s_algorithm
TLDR:
* The mutex is priority based: first-in-first-out (FIFO).
* Memory read & write must be atomic (atomic read-modify-write not required).
* There are N lock levels for N clients.
* The client with the higest lock level holds the lock, and all other clients wait.
* Every lock level has at most one less waiting client than any lower lock level.
* A client can only advance to the next lock level if all higher lock levels are unocupied.
CON
LEVEL_RELEASED = -1 ' Lock levels must be higher
INVALID_ID = -1 ' Client ID's must be higher
VAR
' Max number of clients for this mutex
byte clients
' Address of array of current lock level for each client
word addr_clients
' Address of array of client that is waiting on lock level
word addr_waits
PUB Start(_addr_mutex, _max_clients) : next_addr
Purpose: Setup a mutex
Parameters:
_addr_mutex Address of the mutex data (not allocated here).
_max_clients Maximum number of clients allowed (max. 127, but depends on memory allocated)
Return:
next_addr The address of the byte following the mutex data.
clients := _max_clients
addr_clients := _addr_mutex
addr_waits := addr_clients + clients
next_addr := addr_waits + clients
bytefill(addr_clients, LEVEL_RELEASED, clients)
bytefill(addr_waits, INVALID_ID, clients - 1)
PUB Stop
return
PUB GetMutex : mutex
Purpose: Get the address of the mutex data.
Return:
Address of the mutex data.
mutex := addr_clients
PUB GetMutexSize(_clients) : mutex_size
mutex_size := (_clients << 1) - 1
PUB Aquire(_client_id) | addr_client, addr_wait, client, level
Purpose: Aquire the lock (busy-wait until it is available).
Parameters:
_client_id Client ID of the client to aquire the lock for.
Return:
0, always succeeds.
' Optimization, used more than once
addr_client := addr_clients + _client_id
repeat level from 0 to (clients - 1)
addr_wait := addr_waits + level
' Set client's lock level to current level
BYTE[addr_client] := level
' Last client entering a level waits
BYTE[addr_wait] := _client_id
' Busy-wait while there are other clients ahead of this client
repeat
' Can advance if another client entered this level after this client
if (BYTE[addr_wait] <> _client_id)
quit
' Check all other clients
repeat client from 0 to (clients - 1)
' Ignore the current client
if (client == _client_id)
next
' Check if there is another client at same or higher level
if (~BYTE[addr_clients + client] => level)
quit
' Check if can advance to next level (no clients ahead)
if (client == clients)
quit
PUB Release(_client_id)
Purpose: Release the lock.
Parameters:
_client_id Client ID of the client to release the lock for.
Return:
0, always succeeds.
BYTE[addr_clients + _client_id] := LEVEL_RELEASED
In "if (~BYTE[addr_clients + client] => level)" what happens if two cogs are running and both fetch the same non-zero BYTE[addr_clients + client] before either cog can set the byte to zero?
The algorithm was designed for systems that lack read-modify-write operations. It is overkill when those operations exist.
The algorithm is cleverly designed (I didn't invent it) to break ties. It is basically a funnel, narrowing by AT LEAST one client every level. At the final level, only one client remains, and can pass through the lock.
Consider BYTE[addr_waits + 0], the entry to the mutex. Every client writes to it first. Some client is going to be last, because hub memory is shared (via TDM, and not multi-ported). Whomever is last cannot advance.
The real key to it all seems to be that advancing to the next level also requires that ALL higher levels be unoccupied.
i.e. if there are 10 levels, and one client is at level 7, a new client entering can't advance to level 6, instead it remains at level 0.
