Prop2 FPGA files!!! - Updated 2 June 2018 - Final Version 32i - Page 15 — Parallax Forums
11213151718160
    I think we've got a better solution now.
    At the top of the thread, I've loaded a new file, with some explanation.
  • Chip, is the scope of local variables still the same? With it being only between global variables as now, it makes it impossible to use common names (me, delay, pins, etc) within a COG image. These all become global variables so you end up with me, me2, me3 and so on as you build COG images in your program. Scoping within an org section might be a useful feature.
    Thanks again for putting up with us and giving new toys to try!
    mindrobots wrote: »
    Every time you declare a normal symbol, you've made a new scope for local variables. Maybe I'm not understanding you.
  • RaymanRayman Posts: 16,229
    Syntax looks reasonable.
    BTW: I hope you get a chance to update the documentation with something about the LUT streamer...
  • cgracey wrote: »
    Initial debug ISR's have been moved up to $FFFC0..$FFFFF.
    Event-triggering LONGs have been moved up to $FFF80..$FFFBF.
    (No more complications at the bottom of hub RAM - everything starts at $00000)
    PNut doesn't download to the last 16 longs in hub RAM, anymore, so that you don't have to worry about putting those initial debug ISR's in your code.
    Shouldn't that be the last 32 longs in hub RAM? Preloading data the event-triggering LONGs doesn't seem very useful.
  • cgracey wrote: »
    mindrobots wrote: »
    Exactly, that is the problem I am having the scope is too small for local variables.
    I think it would be useful to be able to:
            orgh $1000
    .me    long   0
    hubentry  cogid .me   ' this .me would resolve to the one defined in the orgh
            org 0
    .me long  0
    cog1entry    cogid    .me   ' this .me would resolve to the one above
            org 0
    cog2entry  cogid .me  ' this .me would resolve to the address of the one below
    .me   long  0
    the variable .me would have scope between orgs. That is, a reference to .me would refer to the .me most recently defined back to the previous org.
    This way PASM code written for a COG would be source portable as long as you used local variables. If I wanted to use code you wrote for a COG as long as I took it from the org to the code, any local variables you used on your code snippet would not conflict with local variables I used in my code snippets. They would be in scope for that org section but nothing else.
    It would be like module scoping if you consider everything between orgs to be a COG module or function scoping if you considered the chunks of code between orgs to be "functions".
    edited 2015-10-13 12:08
    Seairth wrote: »
    No, Chip's description is correct. The event longs ($FFF80-$FFFBF) are immediately followed by the DEBUG ISRs ($FFFC0-$FFFFF). The ROM booter preloads the last 16 longs with IRET0 and you need to change them in your code if you want to intercept them - PNUT never loads these. PNUT *WILL* load the Event longs for you if you define them in your code.
    When I played with the last version of PNUT however, it did not like addresses above $7FFFF, so you still might need to manually load the event vectors once you are loaded and running your code.
  • mindrobots wrote: »
    Wait! That's right! PNUT can't reasonably load anything above $7FFFF, so my comment is moot.
    User Name wrote: »
    Coley wrote:
    IMHO Hub exec mode is the icing on the cake and shouldn't be the driving force.
    I use all sorts of micros depending on the task at hand, the Propeller is by far the easiest and most fun to use.
    I really hope P2 can continue that tradition.
    +1
    David Betz wrote:
    I was under the impression that it was relatively uncommon for most Propeller users to use PASM other than what is included in drivers that they download from OBEX.
    It is FAR FAR FAR more likely for a Propeller user to use ASM than it is for an ARM user to use ASM. I will resist any effort to make the Propeller another ARM chip. At least 75% of all Propeller code I write is PASM because of the Propeller's irreplaceable and almost unique facility to allow a user to create precise custom high-speed signalling easily.
    +1
    The precise high speed signalling the cogs and pasm make possible is my main reason for using the propeller.
  • kwinn wrote: »
    User Name wrote: »
    +1
    +1
    I agree but I still wonder what percentage of Propeller users write that PASM code themselves vs. using an off-the-shelf object that contains PASM code someone else wrote.
    Roy Eltham wrote: »
    Chip,
    [register] usually means indirect through the register, so that works. Although, I would prefer it be consistent, and be used everywhere, not just on branches. In fact, I think we could lose the # to mean immediate, and instead have it be no symbol = immediate, and [] means through register, then the @ can stay as it was beforee you made it the ` (which is awful).
    C/C++ uses & to mean address of when it prepends an identifier (e.g. &routine = address of routine), maybe an option?
    +1, particularly for no symbol meaning immediate. Forgetting the # is the most common mistake I still make fairly often.
    jmg wrote: »
    Well, we need something to denote relative, as opposed to absolute branching.
    I'm unclear on why this is needed ?
    Can the assembler not choose the smallest, most portable form, when using a generic CALL or JMP, and if you want an explicit non-relative form for some reason, use a AJMP or LJMP or RJMP - that avoids yet another special character... ?
    Ah, make new mnemonics for the different types. Interesting.
    That might work well. JMP would be the generic case that would follow some contextual rule, while AJMP/RJMP would force absolute/relative. I wonder if that would just clutter things up on the instruction side, though. It would get rid of both "#" and "@" for branches, which is nice.
    That would apply to:
    JMP/AJMP/RJMP
    CALL/ACALL/RCALL
    CALLA/ACALLA/RCALLA
    CALLB/ACALLB/RCALLB
    CALLD/ACALLD/RCALLD
    LOC/ALOC/RLOC
    It might be better to put the letter on the end. No, that's not going to work.
    That gets kind of busy. Maybe we could use ":" to mean relative and "#" to mean absolute. That is a lot tidier. I think someone suggested using ":" for relative. If we did that, "@" could mean address-of.
    Why mnemonics? The compiler should be able to select between direct and relative based on distance from the current location. Then indirect is the only choice that needs to be specified, and it may need to be specified to take advantage of jump tables in any case.
  • ElectrodudeElectrodude Posts: 1,686
    edited 2015-10-13 14:17
    On the P1, I've experienced a problem where I've needed to refer to what should be a local label from the other side of a global label. Currently, the only solution to this is to make the local label global, further cluttering the global namespace. To alleviate this, could you add globallabel.locallabel syntax to refer to possibly out-of-scope local labels, where .locallabel is a local label that comes after globallabel and before the next global label after globallabel?
    Also, I love the new addressing syntax!
  • I'm happy with the addressing syntax. Time to write more PASM.
  • rjo__rjo__ Posts: 2,114
    ##Me2
    I remember coming to the P1 without any useful background at all. What I really loved is that I could start using both SPIN and PASM without reading anything:) As long as I stuck to the patterns, I was fine. This latest incantation does exactly that for me.
    Well done guys!!!!
    Rich
  • Yep. All part of the beauty. I appreciated it too. Back in the day, when I saw P1 and ordered up a Demo Board, I was able to read through and start working in a day. And that's some tweaking of PASM too. You follow the patterns, and there are only a few variations, so worst case, plug a couple in, until it works. Better understanding comes quickly, but it also comes in the context of doing stuff too.
    Exactly... and show me anywhere else that the hardware description is right there for the experts as well.
    It is all incredible.
    Rich
  • So what is the difference between @ and #@ and ##@?
  • @label is the address of label, as on the P1. #@ means use that address as a 9-bit immediate value.. ##@ means use the address as a 32-bit immediate value, using AUGS to make the address fit.
  • jmgjmg Posts: 15,200
    edited 2015-10-13 16:45
    kwinn wrote: »
    Roy Eltham wrote: »
    Chip,
    I agree, many users will be using more than one MCU assembler, and certainly all new users will have been exposed to some other Assembler
    chip wrote:
    The biggest thing we could do to shorten code would be to get rid of "#" for branches and have register branches use "[reg]".
    Yup that makes sense, plus it is the widely understood/expected syntax, however....
    this also makes sense :
    chip wrote:
    That introduces a wrinkle into the standard Propeller thinking, though. I could go either way.
    I think there is a solution that covers all of this :
    Support
    JMP [reg] '@register branches use [reg]
    as that is a safe superset. ie nothing breaks if you do this.
    (and the code is already done.. :) )
    Support the legacy, but deprecated
    JMP #LabelName
    nothing breaks if you do that, which only leaves..
    Have a simple switch that directs the ambiguous and nonstandard
    JMP LabelName
    to be treated as either of
    JMP [LabelName] ' Indirect jump
    JMP LabelName ' Standard direct Jump
    Prop users who have never used any other assembler, and expect they never will, can use the legacy form.
    New users, and those using multiple assemblers, can use the switch set the other way.(default?)
    edited 2015-10-13 16:44
    kwinn wrote: »
    JMP/AJMP/RJMP
    CALL/ACALL/RCALL
    CALLA/ACALLA/RCALLA
    CALLB/ACALLB/RCALLB
    CALLD/ACALLD/RCALLD
    LOC/ALOC/RLOC
    Why mnemonics?
    Because sometimes you need that control, and those mnemonics generate different opcodes anyway.
    kwinn wrote: »
    Yup, agreed, however some Assemblers are better at this than others.
    IIRC Chip has said PNUT is 2 pass and does not forward resolve.
    Also, gas docs suggest it is worse than yasm, and may need some user-help until it gets as good as yasm
    using mnemonics allow everyone to code now, while the tools get aligned to the ideal.
  • IIRC Chip has said PNUT is 2 pass and does not forward resolve.
    Yes. If we keep this stage simple, the on chip tools will work reasonably well. For those that care, this discussion matters. For everyone, it's a baseline set of functionality that is necessary to bootstrap higher level things.
    Once it's a lock, and we've got bigger and better things going on, the tools one layer up, gcc, OpenSpin, etc... can add a lot of the nice bits people are wanting / needing.
    mindrobots wrote: »
    Yet that is what local means, and how most assemblers manage local ?
    mindrobots wrote: »
    Understood, but that sounds like a problem that needs more than a local change.
    Can you use the form below ?
    Reading the gas / nasm docs, I think they do this.( I've not tried it)
    ie you can use globallabel.locallabel, which I think is one reason they chose the period.
    No idea how easy/hard that is to add to PNUT, but the idea has precedence.
    New syntax still looks great.
    Question: aren't there still enough bits in coginit D field to pass a long-aligned address?
    Since there's now an alignment compiler directive, is this easy to add?
    Maybe upper bits of D could be sent to PARA?
    Rayman wrote: »
    There are only 9 bits in D for an immediate value:
    CCCC 1100111 CLI DDDDDDDDD SSSSSSSSS COGINIT D/#,S/# {WC}
    Ok. Still, isn't that the perfect size for mapping to the <$400 HUB RAM area?
    Rayman wrote: »
    Those nine bits would only reach to $1FF. Remember that we are not forcing long alignment for instructions, like some would prefer, so that we could reduce the PC's by two bits. Those 9 bits count bytes, not longs.
  • Chip,
    Can you answer this question:
    Seairth wrote: »
    Seairth wrote: »
    Chip,
    Seairth wrote: »
    "@" means the-address-of-in-hub.
    "#@" means the-address-of-in-hub, in an immediate 9-bit constant. It had better fit!
    "##@" means the-address-of-in-hub, in an immediate 32-bit constant (20-bit, really). It will always fit!
    I think someone accurately answered this earlier.
  • SeairthSeairth Posts: 2,474
    edited 2015-10-13 18:25
    Seairth wrote: »
    Chip,
    Seairth wrote: »
    Possibly, but with the latest changes, I've lost track. Taking this a bit further, what is the difference between:
    # and #@
    ## and ##@
    edit: And where would you use @ instead of #@ or ##@?
