Servo motor help.
in Accessories
I have searched the forum but no luck. Basically I have purchased a boe-bot and cant find any documentation on how to control the continuous moving servos. I need some code in spin to look over, specifically a way to control speed and direction. I have ran code from the OBEX and its making the servos move one direction but I need more clarity.
Here's some info on using the Propeller BOE to control a BOE-Bot but the concepts will work with any Propeller board.
http://learn.parallax.com/PropellerBoeBot
Here's a link to more Spin tutorials.
http://learn.parallax.com/propeller-spin-tutorials
I hadn't seen these tutorials when I wrote my PropBOE-Bot code.
forums.parallax.com/discussion/comment/1086427/#Comment_1086427
I think there's some very basic servo code at the top of the above linked thread.
Edit: The third post in my index includes links to Propeller tutorials.
Thanks for the links. I cant believe I did not find these.
There are two BOE-Bots, one BS2 based and one Propeller based. Which one?
It's hard to tell since you posted in accessories.
It's a lot easier to search for stuff once you know what it's called.
Don't worry about asking here if you can't find something yourself.
http://forums.parallax.com/discussion/92410/pekbot/p1
I took me a while to find it. I thought I knew where everything was! Can't believe it was from 2007!
Not yours Duane, the one you selected Pub, the PE Kit bot, I think I have the contents of the PE Kit, I believe the PE Kit isn't on the site. Nor is its documentation PDF either. The links point towards an earlier version of the site.....
There's a link to the PEK near the top of the third post of my index (and here). The PDF file is available from the product page's downloads section.
All one needs to do is go to the store site and search PEK. We all know there is broken stuff,
Oh and as it happens Micro Center seems to be selling rather slowly as it happens individual Prop chips in the dip form and the big board as well.
