Updating Parent Array Values from Child Object?
I've been working on a simple PWM reader in spin for my project and it works great as methods inside a single object file but when I use it as a separate object file I cannot figure out how to update my main code data array from the child object. I understand that I will have to pass the address but I do not know how I can use that address to actually change the value of the data stored in the array. I know that I will have to be careful with the read / write timing here as separate cogs will be using this same memory. Here is the framework for what I've got:
Main Code
Child Object "My PWM Reader 0"
I know it's a simple question but I just cannot find the answer...
Main Code
OBJ pst : "Parallax Serial Terminal Plus" PWMR : "My PWM Reader 0" CON _CLKMODE=XTAL1+ PLL16X _XINFREQ = 5_000_000 VAR long stack[100] long PWMdata[10] PUB main cognew(PWMR.start(0,1,PWMdata),@stack) 'start a new cog with the reader on pin 0, 1 pin only repeat 'print outputs to terminal
CON _CLKMODE=XTAL1+ PLL16X _XINFREQ = 5_000_000 VAR long startHi long stopHi byte pin0 byte pinNum byte pin long PWMdat[10] long outputArrayAddress PUB start (startPin, numberOfPins,dataAddress) pin0:=startPin pinNum:=numberOfPins outputArrayAddress:=dataAddress repeat pin from pin0 to (pin0+pinNum-1) DIRA[pin]~ 'sets all pins to inputs repeat repeat pin from pin0 to (pin0+pinNum-1) 'cycle through and read PWM on each pin repeat while ina[pin]==1 repeat while ina[pin]==0 starthi:=cnt repeat while ina[pin]==1 stophi:=cnt PWMdat[pin]:=stophi-starthi repeat pin from pin0 to (pin0+pinNum-1) 'cycle through and update PWM data array values outputArrayAddress[pin]:=PWMdat[pin] 'need help with this
long[childdata] := 1
The main method can then read the data at any time.
Or, as an example in the child obj do long[outputArrayAddress] := 1
then in the main method read the data in PWMdata.
You can't cognew a child object's method. Put the cognew in a new method in the child object.
You need to do long[baseptr][offset] to index arrays by pointer.
main.spin:
childobject.spin:
Also, _clkmode and _xinfreq in child objects are ignored.
I got it figured out. It was mostly the cognew() placement causing something I had already tried to fail.
