Use MIT Scratch with Propeller with this Pico Imposter
Here's a .spin file that makes a Propeller board appear to be a Pico board for Scratch.
Scratch is a visual coding tool for kids at scratch.mit.edu
This version is special for Quickstart so you can interact with the Quickstart buttons.
The P0 button acts like the Pico button.
The other buttons act like the slider.
The Pico is one of the few built-in extensions to Scratch, making it easier to use.
Note: You will need to install a Scratch Browser Extension Plugin to make it work...
See here: https://scratch.mit.edu/info/ext_download/
There's also a demo Scratch program (the .sb2 file) that you can upload within Scratch.
Click the green flag to run.
Pushing the P0 Quickstart button makes the cat move.
The value of the slider (Other QS buttons) is also displayed.
Update: I've attached the full code here so you don't have to search for the QuickStart buttons driver.
It could then be used in ScratchX (but not Scratch unless MIT agrees to make it official).
And Scratch is native on the Raspberry Pi critter.
The Lego thing seems like an afterthought to their big name one.
Convincing a QS board to pose as a Pico board using that Spin file will be a good thing.
Does Berkeley Snap! work on Linux? I think it might as it's all JavaScript...
That one is very similar and extensions are also similar...
The Arduino example shows you how to turn an LED on.
It would be nice to do that...
What's nice about Propeller is that the Spin code is also fairly simple, and maybe kids could also look at that and understand it a little. The Arduino code is much more complex, in comparison...
Anyway, I think there might be an opening for a Propeller version of Pico. But, with the addition of LEDs that you can turn on.
It's always fun to turn on an LED...
Hello!
Okay some other issues to consider. I just tried out your newer Spin example on a QS board under IE11 after redoing the code. It happens that when I tried it out under Chrome, I believed that the files were not loaded in order.
Anyway under Chrome the application did not run properly. Now it works.
I did see that Chrome requires a different browser plug-in, maybe that's the trouble?
Anyway, installing the browser plug-in is really the only tricky part here.
It's a good idea to check your browser's list of installed plug-ins to make sure it's there if it's not working...
By the way, Quickstart really isn't so bad for this... Pico has 8 sensors and QS has 8 buttons, so it kinda works.
QS is also less expensive and can be used in many more ways...
Yes indeed.
What I find amusing is that the Raspberry PI has Scratch as a native. And we now have an IDE for the Prop for it. Talk to the people behind the little guy at their booth at a good sized Maker Faire, they would be quite impressed by it all. I did.
Sparkfun who also sells the Pico (I suspect its one of their Red Board jobs.) was selling a widget who turns the Raspberry PI into a Lego controller. Both Scratch and Python can be used for that. (Then.)
The second option for Scratch as a language to the outside is something from Lego. Probably to fill a "needed skill" that the Mindstorms does not have.....
The Raspberry PI comes with Scratch 1.4. This is from Version 2 so everything inside the file won't run. However.... That version does support the other two. I wonder if the commands can be easily translated from one to the other?
EDIT: Last sentence stricken.
