Propeller Activity Board I2c bus access is missing?
in Propeller 1
Did I miss something on the schematic? Why are the i2c pins on the eeprom non accessible or are they?
There should be a header so I can use more on this bus, right? I suppose parallax had good intentions and if so my curiosity insist I ask politely ask why otherwise blessed may your day be.
Of course any two I/O pins can be used as an alternate bus.
I like how the QuickStart board makes all I/O pins available.
I have a lot of different boards, so not sure if it was the Activity board. But I could not find I2C pins either on the headers.
I do also, but only so a hardware failure won't prevent the Propeller from booting. You cannot code to catch bad hardware if your MCU won't boot.
