i want to make a circuit to detect flow of water using ir leds
i want to make a circuit to detect flow of water using ir leds which will be later on connected to arduino so the thing is I'm from computer department and I don't have much knowledge about electronics. so the thing is which resistor should I use how to find the appropriate one for transmitting and receiving ir signals
http://startrobotics.blogspot.com/2013/05/how-to-use-ir-led-and-photodiode-with-arduino.html
How do you plan on using an ir LED and photodiode to detect the flow of water?
Your problem is physics. How are your going to detect water flow with IR?
Whatever, you should be more specific, this water flow in a household water pipe or a river or what?
The requirement isn't "with IR" it's "using IR LEDs."
This makes it easy. You drop the IR LEDs in the water and see how fast they move.
I do wonder why the "IR LED" requirement is added.
I suppose some sort of paddle wheel which interrupts an IR beam could be used. Of course a lot depends on the specifics of the application.
The question as stated is so vague as to be unanswerable in a sensible way.
Ah, you mean poohsticks?! https://en.wikipedia.org/wiki/Poohsticks
Hmm, but do leds float? More experimentation needed...
After all, that was the basics (similar) to how ships speed (in knots) was determined.
To clarify, are you trying to detect (A) when water is flowing or (B) how much water is flowing? If the answer is (A), then you are looking for an IR break beam circuit. There is plenty of online material about this. Since you specifically mentioned arduino, here's a link to get you started:
https://learn.adafruit.com/ir-breakbeam-sensors
To learn more about this, search google.com for the following words...
water turbidity
water mineral content
water testing
water chlorination
water fluoridation
water pH
Are we talking detecting a presence or absence of a flow of water, from a tap say?
Are we talking measuring the speed of flow in a pipe? In a river?
What actually has the resistor on an IR LED got to do with it?
Oxygenation/aeration could also be introduced from a control point within the flow as well with something like a venturi valve.
Note: The IC below is just a reference to the circuit (See datasheet Figure A on page 11)
http://www.digikey.com/product-detail/en/HCNR200-000E/516-1522-5-ND/696022
Can you elaborate a bit on that idea?
