Emic 2 Text to Speech Converter Interface
in Accessories
I would like to know how to interface the Emic 2 Text to Speech converter to a conventional 8 bit parallel data bus. I'm thinking it might take only one IC, but I don't know which one to choose. Please share any ideas even those you are not sure about. It would be greatly appreciated. Thank you!
There are two basic choices. You can use a standard UART chip like the 16550, or a small microcontroller.
If the cpu controlling the parallel bus is fast enough you could also bit-bang the data in/out.
Post a little more data on the circuitry producing the parallel output and you may get some more detailed suggestions.
