Dismiss option
Others may already know about this, but I just accidentally discovered a "Dismiss" option for (some) Announcements. It seems a bit inconsistent, though. Not all announcements provide the option.
If you want to try it out yourself, hover your mouse just to the left of the "started by" column. A gear should appear, which will give you the ability to dismiss the announcement. Note that, one time, the gear showed up at the far right instead. And, as I mentioned, not all announcements seem to have the option.
Those announcements take up most of the screen it will be nice not to need to scroll down to see new posts.
