Doing my own I2C, would like some hint/help
Erlend
Yes, I know there are plenty of I2C drivers out there, but I want to do it my way so that I really learn the protocol.
I am launching into debugging now, and would appreciate help and hints to where I have failed. The first 'demo' I am trying out is a bus scan routine to check who is connected. The guy who is connected, an MCP32017, does not reply, so there I am.
Before I launch into real head scratching, hook up a scope or an analyzer, start getting entagled in probe wires, debug code, etc. maybe ask the forum for help? The project files are attached.
Erlend
Erlend
PUB Read | ChipAddr, RegAddr, AddrForm, value REPEAT pst.Str(String("Enter Chip address (HEX):")) ChipAddr:= pst.HexIn pst.Chars(pst#NL, 2) pst.Str(String("Enter Register address (HEX):")) RegAddr:= pst.HexIn pst.Str(String("-1-Quit, 1-8bit format, 2-16bit format, 3-32bit format:")) AddrForm:= pst.DecIn pst.Chars(pst#NL, 2) CASE AddrForm 1 : value:= bus.ReadChipA8(ChipAddr, RegAddr, bus#NAK) quit ' need to add this 2 : value:= bus.ReadChipA16(ChipAddr, RegAddr, bus#NAK) quit ' need to add this 3 : value:= bus.ReadChipA32(ChipAddr, RegAddr, bus#NAK) quit ' need to add this -1 : RETURN OTHER: pst.Str(String("Chose -1, 1, 2, or 3!")) pst.Chars(pst#NL, 2) pst.Str(String("Reply from chip: $")) pst.Hex(value, 4) pst.Str(String(" %")) pst.Bin(value, 32) pst.Str(String(" Dec: ")) pst.Dec(value) pst.Chars(pst#NL, 2) pst.Str(String("Completed.")) pst.Chars(pst#NL, 2)I2C has more features, so it is harder place to start out with.
Have inserted the QUITs as you point out. I will continue to test my code against the boot EEPROM now that that I know it works, and then I will investigate later why MCP32017 is not responding. (It is working with your code).
Thanks again for the help,
Erlend
Sounds good. SPI is next, so should be easy now
Erlend
I have always felt the Propeller 1 boot from I2C EEPROM to be a bit slow. From SPI it would be much faster.
I2C has more to offer a shared bus of two wires, but that has never seem to have worked out on the Propeller.
There are other pros and cons. SPI usually requires at least one more i/o pin.
Really? I use the I2C pins in many of my projects -- it has worked out very well. You're right, SPI can be faster, but it takes more pins; as ever, we have to make a choice.
I once coded a project (for an HVAC system in China) that used MCP23017s (I2C) and a bunch of SPI parts. We had so many SPI parts that one of the banks of an MCP23017 was used to control the CS lines of the SPI devices.
One can only assume you're going to write an SPI slave object. There are lots of master objects, what we really need is an SPI slave object!!!
One I'm onto now is the LMP91000 interface to gas sensors (potentiostat). We need to measure 4 gasses, CO, NO, NO2, O3. But it offers only one address, 8-bit $90, despite having NC pins. Instead, the '91000 has an active low chip-select, so multiple devices on a bus requires the same number of pins as SPI.
What triggered my I2C effort was actually the one-address problem you are describing, but in this case the V6180X laser ranger chip. This chip can be reprogrammed to a new address, but looses this after power down. My idea is to stage the power-on of several chips tied to the sam bus - by means of RC delaying the power such that they come 'online' one after another. As soon as the first chip gets alive it gets a new address, then the next, and so on. The Sensirion chip is too stupid though, it even pulls SDA and SCL low when it looses power, and the LMP91000 is not much better - with a fixed address.
Erlend
I've had situations where I've wanted to power down one device on an i2c bus while keeping other devices on the same buss up and running. That entailed use of a bus isolator (TXS0102), to go high impedance on sda and scl.
Today we're working with a CO2 sensor that not only has one available address $D0, but it also uses both clock stretching and a multistep process with checksums to read out a simple word of data. The difficult thing about i2c is usually not the basic steps. It's the variety of higher level protocol and registers they require.
Some use the the 'standard' SPI, and other try to avoid legal difficulties by using an exotic non-standard SPI.
The net result is that a project might end up with both I2C and SPI being involved. And the SPI might be slowed down or modified for just one 'must have' sensor.
Philips (now NXP) developed I2C in the 80's and the licence I believe is not about money but more to do with compliance to the standard if you are wanting to obtain an I2C address. Anyone is free to develop a "2-wire bus" as Atmel have done and SMBus also which is I2C'ish but not necessarily compliant. Some sensors seem to implement their I2C'ish slave interface in software as it seems to be "flakey" and non-compliant.
But the biggest hassle with I2C devices is the setting of its address and it seems to me they should be more like 1-wire devices with a unique serial number as well as an easy fixed address. That way a similar search function could be applied to manage larger sensor networks.
Fortunately this chip has a dedicated boot/reset pin that I can use. Holding it LOW will prevent the chip from booting. A single Prop pin can do all the chip boot pins. I am soon at the stage of testing this scheme.
Erlend
to get ready for a new toy I ordered from SparkFun. Mine has a
40Meter range and with some tricks distance can be sampled
at up to 500Hz. With a $10 off coupon and free shipping I couldn't resist.
A must have! Details please, I need to make sure I have more chips coming in than I have managed to interface, but now I was about to catch up...
Erlend
The thing that sold me on it was it can be setup like a Ping w/ PWM
output representing the distance.
