28044 laser range finder
This assembly works very well but I am sweeping a servo to look for obstacles. The servo sweep code works smooth without the laser called but when the laser is called there is a jerk about 500ms after each angle call.
If I do not sweep but just call the laser routine everything is stable but the jerk still comes about 500ms after the laser flash. The laser code I am using:
void LaserScan()
char lrfData[LRFBUFSIZE];
char offset = 0;
lrfSerial.print('R');
delay(2000);
if(lrfSerial.available() > 0)
{while(1)
if (lrfSerial.available() > 0) // If there are any bytes available to read, then the LRF must have responded
lrfData[offset] = lrfSerial.read(); // Get the byte and store it in our buffer
if (lrfData[offset] == ':') // If a ":" character is received, all data has been sent and the LRF is ready to accept the next command
lrfData[offset] = 0; // Null terminate the string of bytes we just received
break; // Break out of the loop
offset++; // Increment offset into array
if (offset >= LRFBUFSIZE) offset = 0; // If the incoming data string is longer than our buffer, wrap around to avoid going out-of-bounds
Serial.println(lrfData);
lrfSerial.flush();
Serial.flush();
Pretty sure there is nothing in the code causing the servo to jerk?
void LaserScan()
char offset = 0;
delay(2000);
{while(1)
lrfSerial.flush();
Serial.flush();
It doesn't look like you include your complete code, (servo control).
You do not say what platform you are working on.
If you are using a Propeller chip, I would run the servo sweep in a separate Cog.
