Recently purchased a Sainsmart ds1307 + memory chip for arduino and wonder if anyone has interface one with a prop and is it compatable with kye's object for sd cards.
I haven't used a DS1307 board with a memory chip with the Prop, but I'm pretty sure I've used a DS1307 with a Prop. I'm almost sure I successfully used it with Kye's SD object.
Kye's SD driver uses a dedicated object also written by Kye. The object can also access the RAM.
No problem here for the prop.
Enjoy!
