Site Updates
Jim Ewald
The updates that we staged to the stage-forums.parallax.com will be installed on this site later this evening. The next update will be published to the stage-forums.parallax.com server in a few days. Please let us know if you find any issues with the items that have been addressed.
Edit: and, echoing potatohead's comment, thanks!
Features have changed (7/30/2015):
Some changes to the theme have been applied.There is now navigation back to Parallax.com from the forums UI
Links open in a new tab/window
Large images should behave properly
BBCode support was applied, HTML support is being phased out
Comment posts should now have a preview option
Link style has been slightly changed
Old Youtube links posted directly into the window behave differently than those posted using the BBCode Youtube button
Emoticons shouldn't appear in code blocks
Download file names should now match the actual file name
Thanks for all the work to the crew.!
Jim
The BBCode now has a link [>>] as in the old forum to the quoted post, which is nice to see back.
However, currently that feature is partly broken in the stage-forums.parallax.com - works in some cases but gives a Whoops bad link message, when quotes are of the opening post.
Will that detail be fixed before the roll out ? Creating broken links is never good...
Will past "experiments" with HTML, such as scrolling code blocks, remain intact?
Thanks for your work on this!
A failing/working example of the problem is here in this thread :
http://stage-forums.parallax.com/discussion/161726/forum-issues-testing-testing
http://stage-forums.parallax.com/discussion/comment/161726#Comment_161726
Both those links should land in the same place, but the 2nd one fails.
Sometimes the Original-post link works, the failure seems limited to when someone quotes the first post.
I do not see a missing /, - instead I see all posts in a thread follow the general rule of /NN/=Comment_NN
http://forums.parallax.com/discussion/comment/1339862/#Comment_1339862
- but the first post link is not of that form, so the auto-generator fails to create a valid link in that case.
Seems an alias link is needed that does follow the rule ?
eg
The link to the post is:
Whereas the link to the first comment to the post is:
I think what is left is understanding how you are generating the links to the original post (I probably should call it by its proper name, discussion). However you are doing it appears to create a link in the second form from above, but it does so without including the '/' before the '#Comment...'. That omission is the error condition we are discussing, right?
Oddly that doe not happen here:
// It's broken. on('/contact', async () => { return <ContactPage /> });When I manually add a /, it still fails ?
Edit: On the other hand, the editor option to change font is gone.. I like to use courier now and then, it was easy with the editor. Presumably the pre-migration manual method works.. if I can remember it: test test Yes, that worked!
Edit 2: No preview on edit anymore.. although now we have it on new post!
-Tor
In GMail, font is the first button, then Size, then B i u etc
