TACHYON O/S V3.0 JUNO - Furiously Fast Forth, FAT32+LAN+VGA+RS485+OBEX ROMS+FP+LMM+++ - Page 68 — Parallax Forums
16566687071109
  • MJBMJB Posts: 1,235
    Peter or others,
    Where is the best info on how Tachyon works?
    I will have some time on my flight home so thought I would do a little reading on both forth and tachyon.
    I have run Tachyon binary a while ago but I didn't do much with it. So much work has been done on Tachyon that it deserves a closer look!
    You have so much experience with PASM etc. I'd recommend just have a look at the commented source.
    TAchyon.spin + Extend.fth.
    Peter gave lot's of explanations so far - unfortunately they are scattered throughout this thread and some others as well.  And of course there is the getting started document all from the links in his footer.
    MJB, thanks. I will download those files and have a read on the plane.
    Hey! What happened to the signature links?
    Is it a tablet/phone thing?
    I found the Intro but haven't found the links to Tachyon.spin and Extend.fth
    go to his dropbox (see his sig) and just download ALL of it
    then load ALL into a good editor
    then SEARCH is your friend for cross referencing ;-)
    edited 2015-08-02 09:37
    Wireless transmission of water level with TACHYON +ESP8266/NodeMCU/Lua to ThingSpeak.com
    https://thingspeak.com/channels/39235#publicview
    Based on Tachyon+Extend (includes PING)
    This could be done just in the ESP alone, but I want to extend this with other sensors
    and functions later. And even if NodeMCU/Lua is easy to use, it has it's complications,
    and Tachyon is so much more natural to me - after some learning curve ;-).
    Tachyon Code
    { read water level with PING and transmit to ThingSpeak.com via ESP8266+NodeMCU/Lua }
    #P10    == PING_TRIG
    #P11    == PING_ECHO
    #9600 SERBAUD         for ESP8266 (could be higher)
    pub SEROUT ( dataByte pin)
    0 == serpin           pin for Tx to ESP8266
    serpin .
    pri SEREMIT serpin SEROUT ;
    pub SER ' SEREMIT uemit W! ;
    pub WATERLEVEL
        BEGIN
            ESC? NOT
        WHILE
        0
        100 FOR
            PING_TRIG PING_ECHO DISTANCE +
        NEXT
    with placeholders for other data later
        SER ." CR $A EMIT sendData("  .   ." ,170000,120000)" CR $A EMIT CON
        REPEAT ;
    WATERLEVEL AUTORUN
    BACKUP
    ESP8266 / NodeMCU Lua Code
    File: init.lua
    --init.lua
    -- checking pin GPIO14 = (GPIOID = 5)for GND connection
    --    if GND then stop script
    gpio.mode(5,gpio.INPUT,gpio.PULLUP)
    if gpio.read(5) == 1 then
        print("now is time for  tmr.stop(0) ")
        tmr.stop(0)
        cb = function()
            print("Setting up WIFI...")
            wifi.setmode(wifi.STATION)
            --modify according your wireless router settings
            wifi.sta.config("Iberbanda-ebac","Who am I")
            wifi.sta.connect()
                tmr.alarm(1, 1000, 1, function()
                   if wifi.sta.getip()== nil then
                    print("IP unavaiable, Waiting...")
                    else
                    tmr.stop(1)
                    print("Config done, IP is "..wifi.sta.getip())
                    dofile("Deposito_01.lua")
                    end
                end)
            end
        cb()
        tmr.alarm(0,1000000,1,cb())
    end
    File: Deposito_01.lua
    send deposito level and later also flow and temperature to thingspeak
    data is sent via serial from Propeller
    temps = {}
    --- Get temp and send data to thingspeak.com
    function sendData(level, flow, temp)
    local req
    local t1, t2
    temps[1] = level
    temps[2] = flow
    temps[3] = temp
    print(temps[1],temps[2],temps[3])
    -- print("Temp:"..t1 .. "."..string.format("%04d", t2).." C
    -- conection to thingspeak.com
    -- print("Sending data to thingspeak.com")
    tmr.wdclr()
    conn=net.createConnection(net.TCP, 0)
    conn:on("receive", function(conn, payload) print(payload) end)
    -- api.thingspeak.com 184.106.153.149
    conn:connect(80,'184.106.153.149')
    tmr.wdclr()
    print(node.heap())
    req = "GET /update?key=----channel-key
    -- assemble the message
    for i, d in pairs(temps) do
        tmr.wdclr()
        t1 = d / 10000
        t2 = (d >= 0 and d % 10000) or (10000 - d % 10000)
        req = req .. "&field" ..i .."="..t1.."."..string.format("%04d", t2)
    end
    print(req)
    tmr.wdclr()
    conn:on("sent",function(conn)
                          print("Closing connection")
                          conn:close()
                      end)
    conn:on("disconnection", function(conn)
                                    print("Got disconnection...")
      end)
    conn:send(req .."
    end
  • Peter,
             I cannot open (Prop Tool) Tachyon V2.7.spin - " no PUB found"
    Siri
  • Peter,
    Siri
    The dropbox file works in BST and Prop tool
  • Peter,
             I should have given the correct info,I amm sorry.
    The problem is when I try ot get the info to Load RAM or EEPROM.
    At first get Expected " } " when I fix that I get " No PUB routine found "
    Siri
  • Only way to tell what the problem is is if you also supply the link you are using etc as I tested the link I gave against the Prop tool and it worked. Did you check with the link I gave?
  • Peter,
    I have a drop box account and I down- loaded from your drop box.I also down loaded Tachyon_ V 2.4 from
    the dropbox and it works well.
    Siri
  • Peter,
    You are right ,your program works.My desk top's USB port is broken and Tachyon loaded properly on my lap top.
    Sorry for the inconvienance.
    Siri
    edited 2015-08-05 08:03
    Has anybody already a MEDIAN or SORT for Tachyon.
    I want to filter some data (length 10-20)
    thanks MJB
    I believe that the best person for this task is a resourceful German who has access to the data to be sorted :)
    If you give it a shot and post what you've got then maybe we can come up with a more refined an elegant solution.
    Ok, here s.th. to refine
    \ optimized BYTE variant   TACHYON style
    \ - optimized for code size an simplicity, not for runtime speed,
    \ fine for small datasets
    : SORTB  ( bytearray len --  ) \ array address, len of array
      2DUP + ROT ROT
    \ 1+ 2/ 	\ for median we would only need to sort half the array
      1-    \ for SORT only need to sort n-1 times - last is correct automatically
      ADO DUP I 1+ DO I C@ J C@ <    \ < sorts ascending
    		 IF I C@ J C@ I C! J C! THEN
      LOOP LOOP DROP
    pub MEDIANB ( bytearray len -- median )
    	2DUP 2/ + ROT ROT SORTB C@ ;
    TABLE 9bytes  13 | 17 | 4 | 7 | 1 | 26 | 45 | 56 |  2 |
    9bytes 9 LAP MEDIANB LAP .LAP .     \      706.000us 13 ok
    \ 9bytes #10 DUMP
  • I have the following code:
    pub GetData ( -- ) \ Read serial port and place WX data into array SERBUF.
    #57 0 DO
    9 SERIN ' SERBUF I + C! DROP
    LOOP ;
    pub SerMon ( -- ) \ Continuously read the serial port.
    BEGIN GetData 0 UNTIL ;
    If I just run GetData, the array populates correctly. When I use the following:
    ' SerMon TASK? RUN \ Set SerMon to run in background on its own cog.
    the array gets corrupted (perhaps overwritten) and I can't figure out why!
    The idea is to have a cog continuously monitoring pin 9 for serial data, which occurs at roughly 5 minute intervals. When the data is received, it is placed into the SERBUF array, so another cog can parse and display it.
    Any help is greatly appreciated!!
    Michael
    K6MLE
    edited 2015-08-07 03:18
    Just on my phone at the moment but i can see a tick before SERBUF which is not what you want as that returns the address of the code rather than the buffer. So drop the tick and just use serbuf as that returns the address of the buffer.
    EDIT: back on the pc but the other thing to watch out for is the data stack as each cog only maintains a 4 level deep stack in cog memory and if you need more then you should create an array (i.e. 8 LONGS mystk) and set the stack pointer at the beginning of the task (i.e. mystk SP!). The other thing to allow register memory for is if your task needs it's own Forth input and output buffers such as when reading a word from the input stream or printing a number etc. So if you need to do this then create an array of say 128 BYTES myregs and also set these up with myregs 7 COGREG! but in this case you probably don't need to do either.
    Note: Whenever you use the BYTES or WORDS or LONGS to create an array it is always long aligned.
    @FORUM: Where's the source/preview toggle button? I only have source view now. Testing code tags now:
    ' Registers used by PASM modules to hold parameters such as I/O masks and bit counts etc
    REG0		long 0
    REG1		long 0
    REG2		long 0
    REG3		long 0
    REG4		long 0
    txticks		long (sysfreq / baud )	' set transmit baud rate
    txmask		long |<txd			' change mask to reassign transmit
    ' COGREG 7 = TASK REGISTER POINTER
    regptr		long @registers+s		' used by REG
  • Hi Peter,
    SERBUF is defined as such:
    CREATE SERBUF 60 ALLOT \ Serial input buffer
    So when I do " ' SERBUF ", I do get the address of the first byte location of the array, which is what I want (I think). Your point about the stack is well taken and could very well be throwing things off when GetData is running in the background on another cog.
    'tis late here, so I'll give these suggestions a try tomorrow and see how things progress!
    Michael
    K6MLE
    edited 2015-08-07 05:02
    Use 60 BYTES SERBUF rather than the manual method as besides being easier to read and know that it's a byte array, it also initializes the array, as well as aligning it.
    This is how your method looks:
    CREATE SERBUF 60 ALLOT  ok
    SERBUF .WORD 474B ok
    ' SERBUF .WORD 474A ok
    ' SERBUF QD
    0000_474A:   80 72 3C BF  79 0C 0C 0C   0C 00 00 00  00 00 00 00   .r<.y...........
    0000_475A:   00 00 00 00  00 00 00 00   00 00 00 00  00 00 00 00   ................ ok
    But this works the same but it also cleaner:
    60 BYTES SERBUF  ok
    ' SERBUF QD
    0000_474B:   80 00 00 00  00 00 00 00   00 00 00 00  00 00 00 00   ................
    0000_475B:   00 00 00 00  00 00 00 00   00 00 00 00  00 00 00 00   ................ ok
    The other way to create arrays that are not inline with code is to use the ORG and DS words. For instance you could have done this:
    BUFFERS ORG
    60 DS SERBUF
    The ORG sets a DS pointer to BUFFERS ($7300) and 60 DS SERBUF creates a constant with the current DS pointer then advances the DS pointer by 60 for the next DS word.
    BUFFERS ORG  ok
    60 DS SERBUF  ok
    ' SERBUF QD
    0000_474B:   7E 00 73 00  00 71 47 4B   BE BF 0C 0C  00 00 00 00   ~.s..qGK........
    HERE .WORD 4750 ok
    SERBUF QD
    0000_7300:   F0 49 BF A0  A4 EB BF 00   00 EB FF 68  11 01 7C 5C   .I.........h..|\
    0000_7310:   AE 4F BF 00  01 4E FF 84   7E 4E 7F 85  01 5C F3 80   .O...N..~N...\.. ok
    Creating arrays and variables this way allows for the data to be lumped together in one area that may be useful for reading into say from a partition table for instance as all the data fields are contiguous it is possible to deal with individual elements or a range of differing elements.
    edited 2015-08-07 22:01
    State Machine Framework anybody?
    Is there only Peter here sharing thoughts and some code ideas ?
    Anybody built a state machine framework for TACHYON?
    Yes - Peter, I could write one ;-)
    Your gate-controller gives some inspiration
    and your LOOKUP / VECTORS words can help.
    A table with adresses of the action words to execute might be a building-block as well.
    But exchange and sharing is big part of the fun here -
    so I'd like to encourage everybody to increase the fun level here ;-)
    Markus
  • Hi Peter,
    I'm not quite following the proper management of separate cogs and tasks. Could you expand upon the correct usage of myregs 7 COGREG! ?
    Although I've implemented the changes you suggested (that I can understand), the SERBUF array is still getting overwritten somehow.
    I've posted the entirety of my code below:
    \ FORTH support routines for Ultimeter 100 Wall display using Tachyon FORTH on the Propeller.
    \ FORGET ULTIMETER
    pub ULTIMETER ;
    \ CREATE SERBUF 60 ALLOT \ Serial input buffer
    64 BYTES SERBUF
    5 == speed-i \ Wind speed index
    9 == dir-i \ Wind direction index
    #13 == temp-i \ Temperature index
    #17 == Lrain-i \ Longterm Rainfall index
    #41 == date-i \ Day of year index
    #45 == tod-i \ Time of day index
    #49 == rain-I \ Today's rain index
    #P9 == WX-RXD \ Incoming data pin.
    8 LONGS mystk
    pub InitStack
    mystk SP! ;
    #2400 SERBAUD \ Ultimeter comm set to 2400 baud.
    #57 0 DO
    LOOP ;
    InitStack BEGIN GetData 0 UNTIL ;
    \ ' SerMon TASK? RUN \ Set SerMon to run in background on its own cog.
    : SERBUF@ ' SERBUF CR 57 DUMP ;
    pub ASC2HEX ( char -- hexchar ) \ Convert ASCII hex byte to hex.
    DUP $3A <
    IF $30 -
    ELSE $37 -
    THEN ;
    pub ConvField ( idx -- decvalue ) \ Index into the serial buffer and convert a field to decimal.
    ' SERBUF + DUP \ Point to 1st char in field.
    C@ ASC2HEX \ Get/convert char to hex.
    $1000 * \ Put char into 1st hex posn.
    SWAP 1+ \ point to 2nd char in field.
    DUP C@ ASC2HEX \ Get/convert char to hex.
    $100 * ROT + \ Put char to 2nd hex posn & add to previous value
    SWAP 1+ \ Point to 3rd char in field.
    $10 * ROT + \ Put char to 3rd hex posn & add to previous value.
    SWAP 1+ \ Point to 4th char in field.
    + \ hex value now TOS.
    pub rose0 0 LOW 1 LOW 2 LOW ;
    pub rose1 0 HIGH 1 LOW 2 LOW ;
    pub rose2 0 LOW 1 HIGH 2 LOW ;
    pub rose3 0 HIGH 1 HIGH 2 LOW ;
    pub rose4 0 LOW 1 LOW 2 HIGH ;
    pub rose5 0 HIGH 1 LOW 2 HIGH ;
    pub rose6 0 LOW 1 HIGH 2 HIGH ;
    pub rose7 0 HIGH 1 HIGH 2 HIGH ;
    pub W-DIR ( n --- ) \ Light LED n on compass rose.
    SWITCH
    1 45 SWITCH>< IF rose1 BREAK
    46 90 SWITCH>< IF rose2 BREAK
    91 135 SWITCH>< IF rose3 BREAK
    136 180 SWITCH>< IF rose4 BREAK
    181 225 SWITCH>< IF rose5 BREAK
    226 270 SWITCH>< IF rose6 BREAK
    271 315 SWITCH>< IF rose7 BREAK
    316 360 SWITCH>< IF rose0 BREAK
    0 0 SWITCH>< IF rose0 BREAK ;
    edited 2015-08-08 01:37
    K6MLE wrote: »
    Hi Peter,
    \ FORGET ULTIMETER
    pub ULTIMETER ;
    64 BYTES SERBUF
    8 LONGS mystk
    pub InitStack
    mystk SP! ;
    #57 0 DO
    LOOP ;
    InitStack
    #2400 SERBAUD
    DUP $3A <
    IF $30 -
    ELSE $37 -
    THEN ;
    SWITCH
    you need to run SERBAUD from within the task code,
    because it sets a COG local register with the timing data.
    So your new TASK in the seperate COG does NOT get it's BAUDRATE set correctly.
    If you give a complete example of your received DATA string,
    then we might find a much more FORTH-like way to parse it.
  • Hello MJB,
    Below is an example of the string received from the WX station. The header is "$ULTW" and every four values that follow are individual fields of data that is to be parsed. An example is the first two fields here indicate 0000 MPH for wind speed and 0000 for a compass degree value (North, in this case). The dashes are fields not currently supported by my current WX station and hence, are ignored.
    0000_3E47: 24 55 4C 54 57 30 30 30 30 30 30 30 30 30 32 45 $ULTW0000000002E
    0000_3E57: 30 30 46 37 36 2D 2D 2D 2D 30 30 30 30 38 36 41 00F76----000086A
    0000_3E67: 30 30 30 30 31 2D 2D 2D 2D 30 30 44 41 30 34 38 00001----00DA048
    0000_3E77: 44 30 30 30 30 30 30 30 30 00 00 00 00 00 00 00 D00000000.......
    " $ULTW0001234002E" 20 STRING data
    \ data PRINT$ $ULTW0001234002E
    DUP $3A <
    IF $30 -
    ELSE $37 -
    THEN ;
    data +  \ Point to 1st char in field.
    0 4 FOR
    SWAP C@++ ASC2HEX \ Get/convert char to hex.
    ROT 4 SHL OR      \ Put char into 1st hex posn.
    NEXT NIP
    8 ConvField .S CR . CR
    12 ConvField .S CR . CR
    edited 2015-08-09 16:07
    @K6MLE: you can simplify the whole rose and direction thing to a single line:
    	1- 45 / 1+ 7 AND 7 OUTCLR OUTSET ;
    As you can see there is no testing of ranges and vectoring off to a special routine, just simple maths to generate 0..7 and writing that patten directly to P0..P2.
    ASC2HEX can be simplified a little too:
    	$30 - DUP 9 > IF 7 - THEN ;
    Use shifts instead of trying to multiply as an 4 << (or SHL) is equivalent to 16 * just as MJB did in ConvField using a FOR NEXT loop.
    also remember that SERBUF returns the address of the buffer so your dump word (I favor very short words for debug use) should not use a tick before it and you only use the tick in very special cases anyway:
    \ dump serial buffer
    : DB	SERBUF 64 DUMP ;
    The main loop looks like this:
    	!SP mystk SP! 2400 SERBAUD BEGIN GetData AGAIN ;
    Rather than creating InitStack which only ever gets called once and only contains two words it's better to just integrate that into the start of the main loop plus I did a !SP just to make sure it was reset.
    You can use AGAIN rather than a 0 UNTIL which I think is only a PropForth thing. You have BEGIN UNTIL or BEGIN AGAIN or BEGIN WHILE REPEAT structures.
    Then again the whole thing can be simplified a whole lot further too but I will show you this later when you have had time to absorb this.
    EDIT: I have pretty much written a version that runs in the background and reads and extracts the information from the serial input and formats the information on the VGA screen. The serial receive buffering and display task are combined and preprocesses the raw data so that the string:
    $ULTW0000000002E00F76----000086A00001----00DA048D00000000
    becomes:
    ULTW 0000 0000 02E0 0F76 ---- 0000 86A0 0001 ---- 00DA 048D 0000 0000
    and this string is evaluated just like any other serial console input so that we end up with 13 (inc 2 dummies) parameters on the stack and the ULTW sets a deferred action at the end of the line when the parameters are sitting on the stack. These are then saved into variables (for external use) and displayed on the VGA monitor etc.
    K6MLE wrote: »
    also have a look at Peters DropBox apps\EGATE.fth
    there he is running a serial input in a seperate COG.
    edited 2015-08-08 12:25
    @K6MLE:
    @K6MLE: Have a look at your stack usage - I think that basic 4 level stack is sufficient. No need to create an extra one.
    Just fill your stack with some data
    \ in main COG run ...
    8 LONGS mystk
    mystk BL ADO I 2/ 2/ I  ! LOOP
    mystk 30 DUMP
    \ run GetData  in it'S own COG - then check stack again
    mystk 30 DUMP
    Hi Peter,
    I cant find your Gate Scheduler example code any more.
    @Anybody: I am looking for a Tachyon implementation of a hierarchical menu system
    for LCD or terminal / VGA ??
    From Brian Riley I found a code to use a rotary quadrature encoder as input device -
    a great start for interacting with the menu.
    thanks,
    Markus
    MJB wrote: »
    Hi Peter,
    thanks found it in EGATE.fth Google-Docs document
  • If I use:
    64 BYTES SERBUF
    as the SERBUF definition,
    The word 'GetData', which is defined as such:
    #57 0 DO 9 SERIN SERBUF I + C! DROP LOOP ;
    is meant to grab the incoming serial data and begin filling SERBUF. Using SERBUF@, which is defined as:
    : SERBUF@ SERBUF CR 57 DUMP ;
    However, when GetData (running in another cog) runs, the first two bytes are 0D0A, rather than 2455, which is the "$U" part of the "$ULTW" header. All the rest of the field of incoming data appear to come in correctly, but this has me baffled.
  • Update ...
    Problems with serial data not appearing where it should seems to only happen when running the GetData routine in its own cog. If I run everything in the same cog, this data problem doesn't occur. Could there be some sort of stack problem? Not sure what to look for.
