P1 Camera Identity and Vital Signs
rjo__
This is a utility that will automatically identify Omnivision camera modules... most of the ones available on Ebay ($4-$30). And it will give you camera vitals signs: frames per second, pixel clock frequency, pixels per frame, lines per frame, pixel clocks per line, VSync and Hsync polarity, etc. On the Propeller1-2-3 or DE2-115, the same hardware is being used to implement a multiple camera setup. That work will be posted as it is completed.
This entire thread is a work in progress. I'm going to post the code and pictures ... worth 12000 words. Time permitting, I will go back and write it up properly.
This project requires:
1) Propeller Activity Board (although just about any board Parallax makes could be used)
2) An EDU card... nicely made, very flexible... order a dozen of them.
In a pinch, the PAB breadboard can be used.
3) A 2x20 long legged, female header
4) Garden Shears
4) Garden Shears
I have two of these from ICStation.
http://www.icstation.com/cmos-camera-module-ov7670-display-active-size-640x480-sccb-p-1679.html
Do you have any plans to write software to capture an image from the camera with the Propeller?
There is an option in the software to capture images... look all the way down in the Spin section. It isn't showing because there is a repeat right before it that keeps Spin from going further.
But... it only handles greatly reduced pixel rates.
I had it working with the OV5640 and posted it it here somewhere a while ago. In addition to the pixel rate issue, there is the memory issue... it was only good for part of a frame and only in 8 bit gray. Honestly, for some applications, that might be good enough. But I needed more. Phil has the best options available. I love his line sensor... hook it up to a laser line generator and you get a lot of good data as fast as you can handle it.https://www.parallax.com/product/28317
and of course, if you want really world class software support for a camera https://www.parallax.com/product/28320 you can't beat PropCam right now.
I think the P123/P1V will handle 3 cameras (8bit) at 60 FPS... 320x240 without getting a hernia. And I might throw in a laser just for good measure... pun intended.
