Propeller out of stock???
kolyur
in Propeller 1
Sorry if this has been discussed elsewhere but I looked briefly and did not find anything.
I have a commercial product that uses the DIP Prop1. Just had a minor heart attack when I found out DIP and QFP versions are apparently out of stock until the end of October. Anyone know if this is a realistic date? It seems as though my only option until then is to try to adapt the QFN somehow, maybe with a Schmartboard or similar. Any ideas?
Thanks.
Thanks.
This discussion has been closed.
http://www.mouser.com/parallax/Semiconductors/Embedded-Processors-Controllers/_/N-6hpef?P=1z13qcq
http://forums.parallax.com/discussion/131867/
M44D40+ Propeller Basic Circuit Module in DIP40 Form Factor
I managed to find some DIPs in stock at Jameco so that's my plan A for now. (I won't relax until I have them in hand.) I'll keep your suggestion in mind for the future.
John
I remember a longer time ago (3 years?) parallax announced the shortage of propellerchips.The announcement said something about how parallax want to avoid a run out of stock in the future.
As the propeller-chips are not manufactured at parallax of course there are reasons possibleparallax can't be blamed for.
Anyway I'm interested what did happen?
best regards
Stefan
P.S. maybe I got tomatos on my eyes. Where can I subscribe to email-notification?
While there are QFN parts available, last I heard there would be no more QFN parts once existing supplies were exhausted.
This is the third time I recall where prop chips were not available for some months. This is certainly a poor track record for commercial customers.
But parallax can estimate how long the number of prop-chips in stock will last and place an order for a new production-run early enough to have new chips in stock before the last chips are sold.
If the number of sold chips has gone through the roof. Congrats for beeing so succesfull. Anyway parallax should be able to watch the decrease of stocked prop-chips and place an order right in time to avoid a supply-gap.
best regards
Stefan
The variation in prices is interesting.
https://hackaday.io/project/6786-soft-propeller
What a totally awesome module. Brilliant idea.
When can we get some?
But I can of course reserve 1 from the first 4 for "some one from Parallax/forums", that is the best I can do for short notice.
Any idea of a ball park price when you get a bigger batch made?
I know that is a lot of money to have but it isn't like the prop changes frequently. And surely they get a discount from the fab?
C'mon Forumistas, if you have some stockpiled, here's our chance to give back!
I also have some I can provide if someone is desparate. Probably not more than 5-6 though.
Are you talking about this? OZoM: Open Source Zynq on Module
I supported this and I thought you said you had already made modules and would send me one but I never heard anything.
RobotShop apparently has more than 100 in stock:
http://www.robotshop.com/en/parallax-propeller-40-pin-dip-chip-p8x32a-d40.html
Walter
Walter
Sorry to hear you're not feeling well. I guess I'd rather have the DIP40 if possible. Actually, either would be fine. I'm also okay waiting. I just hadn't heard anything so I wondered if the whole project had been abandoned.
Thanks,David
It would be fun to work with your Propeller implementation on the Zynq chips.
Hope you are feeling better soon!
I should be more precise writing from my mind, I did mean that I am not feeling good about not being able to-do things faster.. Work has processes, but there are some feasibility concerns, and design decision, well most to the time the most problem is: CONNECTORS! What kind of the connectors to use, and how to-do reasonable compromises.
OZOM-A board was redesigned 2 or 3 times after REV1, and will get one more redoing, the final.
on DIP40 propeller board I have Zynq booting and loading the FPGA from SPI flash. So the module is pretty much useable as it is now. There are some more things to test, and I need customized bootloader, as the CSG225 package does not boot directly from SD card.
I will most likely do an plain Artix FPGA also in DIP40, its really nice small form factor with EASY use pins.
Mouser has 2,000 QFP's and 300 Dip's:
