BS2 usb to serial adapter question
in BASIC Stamp
Hi,
I am trying to program the basic stamp 2 module using this usb to serial adapter :https://www.pololu.com/product/391 I connected the RTS to DSR, TX to SIN, RX to SOUT. And I connected DTR to ATN through a capacitor. when I try to program it, the module is not identified. there is a loopback and echo, but no basic stamp found. the basic stamp is a new one and working properly with Parallax USB to Serial Adapter. I even tried sparkfun FTDI basic breakout board, but still didn't work. it only works with parallax's adapter.
is there a special connection that I must do in order for these adapters to work?
thank you
thank you
Note: This product does not include printed documentation or software discs. The Pololu USB-to-serial adapter requires software drivers to operate; please see the resources tab for more information.
Have you installed the required driver as indicated?
I tried it on a cheap Chinese FT232 adapter but it didn't work. Read the warnings if you decide to try it, for a while FTDI warned the utility would intentionally brick a counterfeit chip. Not sure if it bricked my chip or not, same (no) response before and after.
