Opinions on P1 pin usage
Wuerfel_21
in Propeller 1
Hi,Im currently trying to design a propeller-based board-thing. I literally sat there for about 2 hours thinking about what to include, being mainly limited by the 32 I/o pins...
So i came up with this:
0..4 = GPIO5 = SD Card CLK6= SD Card MISO7 = SD Card MOSI8 = SD Card select + LED9 = SD Card detect10 = Audio right11 = Audio left12 = SRAM CLK13 = SRAM MISO/SIO014 = SRAM MOSI/SIO115 = SRAM select16..19 = Video DAC 120..23 = Video DAC 224 = Mouse data25 = Mouse clock26 = Keyboard data27 = Keyboard clock28 = I2C SCL29 = I2C SDA30 = Programming header TX31 = Programming header RX
(SD card isn't on the same bus as SRAM so they can be used at the same time. Also i heard that SD's do wired things until they're properly set up.)(SRAM will be Microchip 23LC1024-I/P)(Second video will be used for debugging or broadcast mode)
What do you think? Did i make a mistake?(Me? A mistake? unbelivable!)
"Me? A mistake? unbelivable!" Well, you might check your spelling.
Here's a tip too if you really want to use PS/2 keyboards and mice, all modern ones that are PS/2 compatible normally come with a bulky gender bender. Do yourself a favor and just use USB sockets on you board rather than hard to get PS/2 but run them as PS/2 protocol as the keyboard and mice themselves sense whether to use USB or PS/2 and the gender-bender is nothing but a dumb and awkward connector.
Another thing, I never understand the need for "stereo" sound as it is rarely ever needed as stereo. I always use mono to a stereo socket, saves another pin.
Also I have shared SD clock and data in with the I2C but you are correct in that there are some cards that do funny things, but the clock is normally fine to share anyway and I try to stick to Sandisk cards which never give me problems.
About the SD card, how would the prop differentiate between pulled up and floating? On the AVR, pins connected to nothing read random values, i assume its the same on the propeller. Also, looking at the SD card driver reveals this crazy hookup:
(WTF, where is the codebox?)// Advanced SPI Circuit: (Uses 4 I/O Pins)//// 3.3V// |// R 10KOHM// |// Data Out Pin Number
SD/SDHC/SDXC/MMC data out pin - pin 7 on the card.//// 3.3V// |// R 10KOHM// |//
Write Protect Pin - Connected to ground when the card is writable.// | Floats when the card is not writable.// Write Protect Pin Number --- R 10KOHM The card socket should provide this pin.// | |// Clock Pin Number
SD/SDHC/SDXC/MMC card clock pin - pin 5 on the card.//// 3.3V// |// R 10KOHM// |//
Card Detect Pin - Connected to ground when the card is inserted.// | Floats when the card is not inserted.// Card Detect Pin Number --- R 10KOHM The card socket should provide this pin.// | |// Data In Pin Number
SD/SDHC/SDXC/MMC data in pin - pin 2 on the card.//// 3.3V// |// R 10KOHM// |// Chip Select Pin Number
SD/SDHC/SDXC/MMC chip select pin - pin 1 on the card.//// 3.3V// |// R 10KOHM// |//
SD/SDHC/SDXC data 1 pin - pin 8 on the card.//// 3.3V// |// R 10KOHM// |//
SD/SDHC/SDXC data 2 pin - pin 9 on the card.//// 3.3V// |//
SD/SDHC/SDXC/MMC VDD pin - pin 4 on the card.////
SD/SDHC/SDXC/MMC VSS1 pin - pin 3 on the card.// |// GND////
SD/SDHC/SDXC/MMC VSS2 pin - pin 6 on the card.// |// GND(code end)
Would that work?
It would then be:
0..5 = GPIO6 = SD Card CLK/Write Protect7= SD Card MISO8 = SD Card MOSI/Card detect9 = SD Card select10 = Audio right11 = Audio left12 = SRAM CLK13 = SRAM MISO/SIO014 = SRAM MOSI/SIO115 = SRAM select16..19 = Video DAC 120..23 = Video DAC 224 = Mouse data25 = Mouse clock26 = Keyboard data27 = Keyboard clock28 = I2C SCL29 = I2C SDA30 = Programming header TX31 = Programming header RX
What would this "propeller-base board thing" be used for: programming the prop, or controlling another system, or games?
Knowing the final intention up front can help when starting the design.
Don't forget pullups on the i2c lines.
I agree with Peter about using the chip select internal pullup for detecting card present. If you don't like the microsecond pulse idea, then connect the pin to ground with a 20M? resistor or even a reverse biased diode. That is enough to keep the pin at ground (and testable) until a card is inserted. The pullups on the other pins are usually superfluous too. Will your system normally have a card present? Forget about the complicated connections to the card detect and write protect switches.
For audio, unless you use a special amplifier, there will be a click when the audio starts as it biases to half-voltage. I don't like that and use a differential prop output to a BTL (bridge tied load) amplifier. There are stereo preamps that have anti-click circuitry.
With regard to the code block, Phil came up with an html workaround, a template if you will:
http://forums.parallax.com/discussion/161593/forum-request-scrolling-codebox-please
Until such time as the forum regains the BBcodes.
Many prop circuits don't have a pull-up on SCL. I recommend pull-ups on both SDA and SCL.
I have been placing a 10K pull-up on SD-CS before Peter pointed out the spec. However, I often share this pin which requires a pull-up anyway.
I have also been putting a 10K pull-up on reset and including an option for the transistor circuit. This allows cheap usb-serial dongles to be used.
In my experience the capacitive coupling between neighbouring pins is enough for a floating
pin to pick up the waveform of neighbouring driven pins quite easily.
