Using the Propeller as a Clock Source
in Propeller 1
Some CMOS chip cameras require an external clock source. They nearly all accept a 24MHz, 50%duty cycle clock. The Propeller handles this very nicely.
In the data sheets of some cameras as the clock frequency changes from 24MHz(in either direction) the duty cycle also has to change.
Can the Propeller generate a variable duty cycle for frequencies in the range of 8-80Mhz?
