TACHYON O/S V3.0 JUNO - Furiously Fast Forth, FAT32+LAN+VGA+RS485+OBEX ROMS+FP+LMM+++ - Page 67 — Parallax Forums
16465676970109
  • When we have nothing else to do we will find something to complain about, and while I'm not impressed with the ongoing issues with the forum implementation I'd rather get on with what I'm doing and the ongoing really slomo development of the BREAKOUT video game. I've been hoping that some might dip their big toe into these waters and contribute, even just a little but otherwise I'm using this as an example in developing Tachyon apps.
    So now I've added simple ball physics with a bounce method which basically translates the ball movement control digit (7 is up and left, 3 is down and right etc) into a corresponding bounce direction so that a ball that hits the left wall when it's control digit was 7 will return a new direction of 9 for instance. Very simple and easy to follow, even interact with the game routines and single step etc. Ball physics will be enhanced bit by bit so that anyone who wants to can follow along.
    The game code size is only around 1.2k
    This is the read-only source code document link btw.
  • Could you write a forum in Forth and solve all of our problems?
    hehe, lol, yeah, but  then it wouldn't be a forum, it would be a forthum :)
    Funnily enough, I had already given it some passing thought simply to scope out how I would implement it and what would be required etc. Imagine though a whole bank of Propellers serving up the forum and if you didn't like the way it worked you could specify your own "script", w00t!
    Then I think of the 800+ man-hours that have been spent on just porting the forums, that's a lot of Forth-seconds there that if devoted to writing code would certainly result in it being worthy of consideration, it might even max out a Prop or two! Would be even better to run the forum on P2, woot woot!
    edited 2015-07-09 13:13
    So super cool, I have loaded the EASYFILE FAT32 filesystem, the WIZnet W5500 driver and EASYNET servers, as well as the VGA drivers and the BREAKOUT game. What's super cool? It all fits in an unexpanded Prop, serves up web pages and FTP files from a FAT32 SD card, and Telnet into Forth all while playing a game of breakout on the VGA monitor.  Still have 4 cogs free.
    Next thing to do is to add sound effects wave files. If you telnet into it at tachyonforth.com port 10001 you can check the score with "score C@ ." for instance. Of course once you telnet in you can pretty much do anything that you could do over a serial console.
    Because the Propeller is multicore there is no induced lag in the game or networking.
    EDIT: there was still room to squeeze in the Game of Life which I can run serially over Telnet while of course Breakout is playing on the VGA monitor.
    edited 2015-07-10 14:02
    Here's a little VGA screen dump word that reads the screen memory and translates the characters as well as formatting a frame for it over serial. So while the game is running I can Telnet into it and type SPY to spy on the game with a live action moving update and this is what I get:
       ________________________________
     |3 balls TACHYON BREAKOUT 037/128|
     |________________________________|
    Hit enter to exit.
    : LOOK
    	2 SPACES "_" 32 EMITS
    	@VGA 960 ADO
    	 CR PRINT"  |" I 64 ADO
    	   I C@ I 1+ C@ 2 >> 1 AND OR
    	   DUP BL < IF DROP "=" THEN
    	   DUP $FB = IF DROP "*" THEN
    	   DUP $7E > IF DROP "-" THEN
    	   EMIT
    	 2 +LOOP PRINT" |  "
    	64 +LOOP
    	CR PRINT"  |" "_" 32 EMITS "|" EMIT
    : SPY	CLS $0C EMIT BEGIN HOME LOOK KEY $0D = UNTIL ;
  • I'm pretty sure I crashed your server.  Sorry.
    Also, every time I ran TEXTBOX on your server, it stopped responding to everything but "bye" and ^C.
    I have a Quickstart board with a W5200 board.  I should probably be more considerate and crash my own server instead of yours in the future.
    edited 2015-07-10 15:14
    Don't worry, that's why it's online, to play with, and crash and burn etc :)
    The textbox function does not return to the console but selects VGA as it's output device. Simply typing CON will return it back. It did kinda crash but I just did a reload by typing "LOADROM BREAKOUT.ROM" which loaded 64k of the EEPROM from file and it was all good again.
    Do you want a binary for the QS and W5200?
    OK, thanks.  I was trying to write stuff on the VGA and then look at it with LOOK.
    I think I crashed it again.  I would love a binary to run on my own system.
  • I decided to make some changes and couldn't seem to get it right since it was 3 in the morning and I needed some sleep. I will fire it back up later on and leave it alone while I run my tests on another board. I will also make a binary for the QS seeing that can have a W5200.
    edited 2015-07-13 00:12
    Congratulations Peter. You have the only useful and interesting thread in the last week or so ;)
  • MJBMJB Posts: 1,235
    edited 2015-07-17 15:13
    SERIAL SPEED TEST
    in an other thread was the question of how fast to transfer samples of 12 bytes.
    So I was curious what sustainable transfer rate I could get with TACHYON
    without using a RUNMOD (which can of course be much faster).
    { high speed serial in TACHYON
    Streaming speed test
    MJB 2015-07-17
    Assumption:
    Transfer 3 longs from memory as fast as possible
    We just set the transfer baudrate and write out,
    then set it back to have the terminal again.
    LONG cnt1
    LONG cnt2
    cnt1 ~
    cnt2 ~
    pub SPEEDTEST
    80000000 3000000 /&nbsp;&nbsp; 3 MBit/s
    5 COGREG!
    10 FOR&nbsp;&nbsp;&nbsp;
    &nbsp;&nbsp;&nbsp; CNT@
    &nbsp;&nbsp;&nbsp; DUP (EMIT)
    &nbsp;&nbsp;&nbsp; DUP 8 SHR (EMIT)
    &nbsp;&nbsp;&nbsp; 8 SHR (EMIT)
    &nbsp;&nbsp;&nbsp; cnt1 @
    &nbsp;&nbsp;&nbsp; 8 SHR (EMIT)&nbsp;&nbsp;&nbsp;
    &nbsp;&nbsp;&nbsp;  cnt1 ++
    NEXT
    694 5 COGREG!&nbsp;&nbsp;  set back to 115200 BAUD
    LAP SPEEDTEST LAP .LAP
    LAP SPEEDTEST LAP .LAP&nbsp; 1.600ms ok&nbsp;&nbsp;&nbsp;  for 10 times 12 bytes each
    1600 120 / . 13 ok
    10000 16 / . 625 ok
    gives 6.25kHz ( not yet 14.4 kHz) transfer rate of 12 bytes ...
    {  or as a runmod would be easily much faster
      - hope the code tags still work
    this means at a raw UART speed of 3MBit/s
    I get an actual sustainable transfer rate of only 600kBit/s (which is not bad ;-)
    just in high level interpreted TACHYON Forth.
    It is also easy to write a little few lines PASM module to be loaded,
    that can then go much faster.
    Probably  Peter knows a few tricks to get even my simple Tachyon code faster ...
    :arrowl:
  • BBCodes are on the list. :)
    edited 2015-08-06 21:36
    SERIAL SPEED TEST
    MJB 2015-07-17
    Assumption:
    LONG cnt1
    LONG cnt2
    cnt1 ~
    cnt2 ~
    pub SPEEDTEST
    80000000 3000000 /   3 MBit/s
    5 COGREG!
    10 FOR
        CNT@
        DUP (EMIT)
        DUP 8 SHR (EMIT)
        DUP 8 SHR (EMIT)
        8 SHR (EMIT)
        cnt1 @
        DUP (EMIT)
        DUP 8 SHR (EMIT)
        DUP 8 SHR (EMIT)
        8 SHR (EMIT)
        cnt1 @
        DUP (EMIT)
        DUP 8 SHR (EMIT)
        DUP 8 SHR (EMIT)
        8 SHR (EMIT)
         cnt1 ++
    NEXT
    694 5 COGREG!    set back to 115200 BAUD
    LAP SPEEDTEST LAP .LAP  1.600ms ok     for 10 times 12 bytes each
    1600 120 / . 13 ok
    10000 16 / . 625 ok
    :arrowl:
    found some improvement
    LONG cnt0
    LONG cnt1
    LONG cnt2
    cnt0 ~
    cnt1 ~
    cnt2 ~
    pub SPEEDTEST
    921600 CONBAUD
    3000000 CONBAUD
    115200 CONBAUD
    5 COGREG@
    5 COGREG!
    10 FOR
        CNT@ cnt0 !
        cnt0
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@ (EMIT)
        cnt1
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@ (EMIT)
        cnt1 @
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@ (EMIT)
         cnt1 ++
    NEXT
    LAP SPEEDTEST LAP .LAP  931.600us ok     for 10 times 12 bytes each
    1000000 931 / . 1074     = 10.74kHz @ 12 bytes / sample
    1074 12 * 8  * . 103104   ->    1.03 MBit/s  transfer rate at baudrate 3 MBaud
    ok - one more
    [code]
    3 LONGS data
    pub SPEEDTEST
    921600 CONBAUD
    3000000 CONBAUD
    115200 CONBAUD
    5 COGREG@
    5 COGREG!
    10 FOR
        data
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@++ (EMIT)
        C@ (EMIT)
    NEXT
    LAP SPEEDTEST LAP .LAP  798.000us  ok    for 10 times 12 bytes each
    1000000 800 / . 1250      =  12.5 kHz @ 12 bytes / sample
    1000000 800 / . 1250 ok
    1250 12 * 8 * . 120000      =  1.2 MBit/s streaming capacity
    without extra PASM - just interpreted TACHYON Forth code
    edited 2015-07-18 04:34
    ok - one more
    Here's one too, I just transfer a block of 1k bytes which takes 6.148ms at 4Mbps. This is about the fastest rate I can transfer at asynchronously but synchronized transmissions can run at much higher rates. The code is simply setting the tx bit-time directly in COGREG 5 and then dumping the 1k block at BUFFERS directly to (EMIT) rather than EMIT which is a higher-level revectorable word that normally defaults to (EMIT). The transfer rate is around 1.3Mbps at 4M baud.
    BTW, the transmit routine is not buffered, it is bit-bashed directly from the running cog so it is actually better to run faster rather than slower.
    : TXBLK ( baud -- )
    	CLKFREQ SWAP / 5 COGREG!
    	BUFFERS $400 LAP ADO I C@ (EMIT) LOOP LAP
    	50 ms
    	CLKFREQ 115,200 / 5 COGREG!
    	.LAP
    4,000,000 TXBLK 6.148ms ok
    1024,000,000 6148 / . 166558 ok
    166558 8 * $400A .NUM 1,332,464 ok
    edited 2015-07-18 08:29
    166558 8 * $400A .NUM 1,332,464 okeh Peter -
    just raising raw baud rate to beat me I'd consider cheating ;-)
    at 4MBaud raw my code gives even a slight improvement over yours ;-)
    LAP SPEEDTEST LAP DUP .LAP  701.600us   ok    for 10 times 12 bytes each
    10000000 7016 / . 1425      =  12.5 kHz @ 12 bytes / sample
    1425 12 * 8 * . 136800      =  1.368 MBit/s streaming capacity
    the enrolled
    C@++ (EMIT)
    is just a tiny bit faster than the loop even on small block size
    so to meet the 14.4 kHz @ 12 bytes / sample requested in the other thread looks like some PASM is needed.
    But good to know the limits.
    Also, this is only the sending side here. Would the standard receiver just do the 4MBaud ?
    edited 2015-07-22 05:04
    Fancy a simple VGA digital clock? How about this one which uses the "big digit" mode for a nice and simple and very easy to read display.
    BYTE dtfl,pm
    LONG clk
    pub (CLOCK)
         --- service every 500ms
        runtime @ clk @ 500 + > 0EXIT runtime @ clk ! dtfl C++
         --- read time and seperate the hours mins seconds
        TIME@ 100 U/MOD 100 U/MOD
         --- adjust the 24 hour time back to 12 hour and display 00 hours as 12
         DUP 12 > DUP pm C! IF 12 - THEN DUP 0= IF DROP 12 THEN
          --- display time in big digits
         VGA yel HUE BIG
         2 4 XY 2 PRINTDEC
        16 4 XY 2 PRINTDEC
          VGA
        --- print seconds
         28 10 XY 2 PRINTDEC
         --- print AM or PM
          28 4 XY pm C@ IF ." PM" ELSE ." AM" THEN
         --- plot flashing colon
         14 6 XY dtfl C@ 1 AND PLOT 14 8 XY dtfl C@ 1 AND PLOT
        --- date as DAY date, month year
         red HUE 9 13 XY .DAY SPACE DATE@ 100 U/MOD SWAP 2 PRINTDEC
         --- month and year
          ." , " 100 U/MOD SWAP .MONTH SPACE 2000 + 4 PRINTDEC
         --- draw a frame around it
         blu HUE 0 0 XY 31 15 BOX
         CON
    pub CLOCK    &#39; (CLOCK) keypoll W! runtime @ clk ! ;
    800 x 463 - 36K
    Nice clock Peter :)
    Thanks Ray, I have made some improvements to it since and added temperature and humidity readouts to it as well and will probably add some other information too yet. Since I have Ethernet running on it too I could probably update it remotely as well as reading weather reports. Then I could run the wave audio to a speaker and have it announce local weather warnings too as well as logging the information. With the RS485 on-board it's easy to link into other systems on premises as well as supply power on 4-core.
    WOW Peter, this has certainly progressed!
    Makes a very nice tool/block base for your products.
  • Well it really isn't progress technically, just application of what I already have. The VGA driver and clock etc occupy one tiny little corner of the Prop sitting on top of the Tachyon kernel and extensions and the SD filesystem and network servers. I might add some of my RS485 networking to the extensions as standard though. I also need to have another look at extracting weather information from websites if I want to add that feature. All this on a single unexpanded Prop with cogs to spare, now that's the "beauty" of it.
    Yes, I am in awe of your Tachyon. While I don't understand forth, the snippets of what I have seen are easy enough to use. And yes, all on a prop with spare cogs. It's speed is amazing for a higher level language!
    Hi Peter,
    I wrote a very simple and very fast stream parser for extracting data from web sites last year.
    Shared it with you on GoogleDocs.
    Markus
  •  I also need to have another look at extracting weather information from websites if I want to add that feature.
    Hi Peter,
    Markus
    Good, are you volunteering to do a demo to display the weather information on a VGA monitor, or even a terminal screen? :)
    edited 2015-07-22 14:28
    Hi Peter,
    Markus
    Since the networking on my Tachyon on Spinneret is broken I can only show how I would parse the file.
    Which URL do you want to get what data from?
  • Since my Tachyon on Spinneret is broken I can only show how I would parse the file.
    The versions I am doing now are not compiled for any target in particular, they just rely on a simple config that can be applied after loading a binary. I will test that this is so on an actual Spinneret although I might have to massage the older W5100 features a little to fit in with the W5200 and W5500. So the idea is that you specify the pins used by the SD card and WIZnet etc and even specify the type of I2C RTC by name. For instance if I use MCP79410 I just type that in and the RTC routines work automatically but I can just as easily say DS3231 or whatever common ones are predefined. The Seiko RTC used on the Spinneret is a bit of a weird one though, it's not really I2C so I might end up still doing a special binary just for the Spinneret I think :)
    edited 2015-08-06 21:02
    That VGA digital clock works well except I wanted to fill the screen a bit more so I added 7x9 and 6x8 big fonts to the VGA driver as well as the 5x7. So with a little positioning I can fit the time right across the width of the screen.
    If anyone wants to try it out then here is the binary for it (Updated 150729). The clock runs in it's own cog so you can play with Tachyon all you like while it's running. If you happen to have a DHT22 humidity/temperature sensor then hook it up to a pin and specify the pin used with:
    <mypin> ' dhtpin 1+ !
    If you want to keep the setting then type BACKUP. All that this does is change a runtime constant and to disable it use -1 as a pin value.
    I use I2C RTCs such as the DS3231 or MCP79410 although PCF8583 and the like should work too. You may have to type in MCP79410 if you are using that chip but normally there is no need to type DS3231 etc to set other RTCs.
    TACHYON [~
    FORGET BIGCLOCK.fth
    pub BIGCLOCK.fth	." BIG DIGIT VGA CLOCK with temperature and humidity 150727-1000 " ;
    --- VGA app for big clock ---
    BYTE dtfl,pm
    pub (CLOCK)
    time @ 100 U/MOD 100 U/MOD
    --- display time in big digits 7X9
    VGA yel HUE 7X9
    --- most sig hours digit will only ever be 1 or blank so adjust left one pixel
    -1 3 XY
    DUP 10 < IF SPACE ELSE ." 1" THEN
    --- least sig hours digit can butt up against the blank or 1 a little closer
    col -- 10 MOD PRINT
    --- now there is room for a flashing colon
    dtfl C@ 1 AND col @ DUP 5 XY OVER PLOT  9 XY PLOT
    col ++
    --- minutes color --- red minutes every 5 mins (marker)
    DUP 5 MOD 0= IF red HUE THEN
    --- minutes
    3 row C! 2 PRINTDEC
    VGA cyn HUE
    --- print seconds
    28 12 XY 2 PRINTDEC
    --- print AM or PM
    28 2 XY pm C@ IF ." PM" ELSE ." AM" THEN
    time 4 + @ 100 U/MOD ( dm yymm )
    wht HUE 9 1 XY .DAY
    --- print month
    SPACE 100 U/MOD SWAP .ASMONTH ( dm yy )
    --- print dayofmonth
    SPACE SWAP 2 PRINTDEC ." ,"
    --- print year
    SPACE 2000 + .DEC
    --- print format for humidity and temperatue with trend arros
    pri .HT ( val var x y -- )
    XY 2DUP AVG > IF red HUE 4 ELSE @ 2/ 2/ SWAP OVER < IF blu HUE 5 ELSE BL THEN THEN VCHAR
    grn HUE 0 1 VGA .DP
    --- DHT22 temperature and humidity sensor - to change:  ' dhtpin 1+ ! BACKUP
    --- to disable: -1 ' dhtpin 1+ ! BACKUP
    -1	== dhtpin
    --- averages
    LONG avgc,avgh
    pub (WEATHER)
    --- read temperature and humidity from DHT22 sensor else dummy if -1 specified
    dhtpin 1+ IF dhtpin DHT ELSE 500 250 THEN
    avgc 2 13 .HT ." 'C "
    avgh 22 13 .HT ." %rh "
    --- display timing
    LONG clk
    8 LONGS dstk
    $7F00 == dregs
    pub BIGCLOCK
    --- setup stack and registers for new task
    7 COGREG@ dregs $80 CMOVE
    dregs 7 COGREG! dstk SP! !SP
    --- setup VGA
    !VGA  blu HUE 0 0 XY 31 15 BOX
    runtime @ clk !
    BEGIN
    !SP
    runtime @ clk @ 500 + U>
    IF
    runtime @ clk !
    dtfl C++
    (CLOCK) (WEATHER)
    THEN
    AGAIN
    --- Setup a keypoll to read the time and date into global variables to avoid I2C bus conflicts
    pub ?RTC	TIME@ time ! DATE@ time 4 + ! ;
    pub MAIN	' ?RTC +POLL httime ~ ' BIGCLOCK 3 RUN ;
    END
    ?BACKUP
    AUTORUN MAIN
    800 x 447 - 61K
    Has anybody already a MEDIAN or SORT for Tachyon.
    I want to filter some data (length 10-20)
    thanks MJB
    edited 2015-08-01 03:00
    thanks MJB
    I believe that the best person for this task is a resourceful German who has access to the data to be sorted :)
    If you give it a shot and post what you've got then maybe we can come up with a more refined an elegant solution.
    Peter or others,
    Where is the best info on how Tachyon works?
    I will have some time on my flight home so thought I would do a little reading on both forth and tachyon.
    I have run Tachyon binary a while ago but I didn't do much with it. So much work has been done on Tachyon that it deserves a closer look!
