Propeller P8X32A IIC Help
in Propeller 1
Can someone point me in the direction of operating Propeller C code that implements bi-directional communication on the IIC communication bus?
Sincerely,
Discovery.
Sincerely,
Discovery.
Hal
Discovery
and unquote.
For reasons known only to the select few that actually write the datasheets, a device's I2C address is always buried deep in some dark, musty crevice of the data sheet. Instead of proudly proclaiming at the beginning of the data sheet "This device's I2C 8 bit address is 0xA0 and in 7 bit format it is 0x50, they bury it near the end, most often in a binary image in the I2C protocol section. I guess its like where the grocery stores put the milk in the far corners so you have to go through the whole store (datasheet in this case) to get what you need.
Discovery
