Forum issue: Links open in same window
When you click on a link to an external site it's opened in the same window/tab as the discussion page you're reading. This can lead to losing your place in your reading. People may forward click and not return.
Let's remember that many reading this forum are guests, and Parallax has a vested interest in keeping them on this site, and not off exploring other sites that could compete. (This includes links in sig lines, which now open in the same window.)
And yes, opening a link into new window/tab is how it worked in VB, and is pretty much the standard on most sites.
Boy, I have a lot of tabs open.
And attachment open in the same tab. Must remember to hit the back arrow.
Along the same lines I'd like to see images pop into a lightbox, rather than into the page. My habit is to then close the tab/window, and then I've lost where I was.
Lightbox code can be added to the theme with a plugin (I assume there's one out there for this forum), but definitely hand-coded.
After all an image is part of my presentation, like:
I did this:
then i did this:
Probably want to make sure images are never so big on the page.
Oh yeah, don't worry about the bandwidth usage of images on mobile
If the responsive features of the forum are working properly, any original size image should fit the screen, regardless of the device. I know there are some reported instances of this not happening. Usually this is a only a problem with legacy browsers, like IE7 or IE8. Shouldn't be happening with mod'ren stuff.
This has been added to the issue list.
