Forum issue: Removal of excess spaces / line feeds, etc... — Parallax Forums
Our new forum allows this:
and this:
  • I think that's a good thing
    I concur.
    edited 2015-07-06 16:21
    (how to delete a post)
  • One thing I've noticed is bizarre automatic formating done by the forum software. It will occasionally add unnecessary line breaks in the middle of sentences, or add 4 or 5 line breaks when 2 would have been sufficient. Some links open in the same tab, though most open a new tab. It often changes font size for no apparent reason from one paragraph to another within the same post. It all seems to be very random and inconsistent.
  • Thank you,
    Oddities in post formatting and allowing excessive whitespace has been added to the issue list.
  • jmgjmg Posts: 15,200
    Allowing someone (who really wants to) add white spaces is not a bad thing. However, adding extra lines the user did not ask for, or changing fonts, is a bad idea.
  • I think it would be wise to limit blank lines between text lines to one. That's all it takes to delineate paragraphs, and there really isn't a legitimate use for multiple conterminous blanks lines that I can think of.
