New Forum Issue: Default sort type
DavidZemon
Default thread sort is by vote, not date. This isn't StackOverflow, it should obviously be sorted by date, not votes.
As an aside, I love the voting system
. Something I've wanted in forums for a long time.
-Tor
Some posts have been conversational, where a single 'answer' isn't the best for the overall goal of a discussion; however sometimes an individual may want a very specific concise answer, as is the case of stack overflow since you mentioned it.
We'll keep an eye on it for certain and see if it ends up causing more harm than good, and adapting as needed to fit usage.
Some forums have a *solved* tag for the title, and a link to the 'correct' answer.
Certainly, default choice of sort by votes is broken/dumb, and should change to date sorted.
Intel has something similar for their Edison product. Posters have the option to select a correct answer, and that's promoted to right below the question. I like that feature.
https://communities.intel.com/thread/76562
If you're aware of the fix, why not change the default sorting to date right away. Users are already upset with so many changes and you know how to make one of those changes go away. If you/Parallax want to try out vote sorting down the road, it seems like later would be a much better time than now.
Indeed. We can essentially breakout the 'solved' or 'highest voted' or some form of answer and display it separate from a date-sorted discussion below. That is not outside the realm of possibilities.
Could such posts be displayed both at the top and where they belong chronologically?
EDIT: This is my second post on the new forums, and I still have 0 posts.
It's a subtle hint
Bump, unless you're contemplating the eminently saner route of a complete roll-back to the old forum, this needs to be fixed -- pronto.
I actually had thought it would be great in every forum, as it allows high quality responses to bubble up, a la slashdot. However I now see that it is just as easily abused/mis-used and can subvert that process depending upon discussion type.
I agree, some of these complaints that seem to be an easy fix should just be fixed. At this point its pointless to try and instill some sort of orderly process.
Flip the switch on some of the universally agreed upon issues.
Slashdot has quality responses? Haven't seen that it some years:)
I think slashdot is a different use case. It's not a forum. It's a comment on a news item site.
On comment site you expect to basically just have a bunch or random comments thrown at the wall, the action on any story only occurs for a few hours or days and then it's all forgotten. Like people shouting at a foot ball match.
On a forum we expect to have topics to discuss and then a long thread of debate.
Sure some of those topics are just questions that get a few quick replies and we move on. stack overflow style. Some topics are long lived, like a discussion of some ones project or use of a particular device or product etc.
Having posts randomized by votes makes sense for slash and stack overflow, not a discussion forum like this.
What is the time period that you get logged out?
I'm not sure what the timeout is on this forum.
Wow, that has to @Bump the priority of removing the silly sort by votes default.I thought it was at least with a work-around, but I think I have not logged off/on
