New Forum Issue: Links via Google/Other Outside Resources
DavidZemon
Old links to the forum no long function correctly, and only direct to the new forum home page. Google will eventually get this fixed over time, but hand-written links from blog posts, emails, other forums, facebook, etc are all toast.
For instance, the link to my beloved PropWare thread is now dead :'(http://forums.parallax.com/showthread.php/157005-FYI-PropWare-Complete-build-system-and-library-for-PropGCC
The link you posted above seems like it is about to, but then stops and redirects to the homepage. I'll figure out why.
I think the numbers have changed.
Google suggested the original showthread.php/123170 was what i wanted,
but quite some digging finds this
http://forums.parallax.com/discussion/comment/992526/#Comment_992526
with this as a root
http://forums.parallax.com/discussion/123170/propbasic-reciprocal-frequency-counter-0-5hz-to-40mhz-40mhz-now
and this base-link seems to work
so maybe the trailing punctuation is an issue ?
'Just now noticed my avatar: apoplectic purple with an expression of incredulous astonishment. I think I'll keep it until things get ironed out -- or better yet, rolled back.
The original thread has this URL:
http://forums.parallax.com/showthread.php/123170-PropBasic-Reciprocal-Frequency-Counter-(0.5Hz-to-40MHz)-40MHz-now-!!!
Whereas the Vanilla version maps to this:
http://forums.parallax.com/discussion/123170/123170-PropBasic-Reciprocal-Frequency-Counter-(0.5Hz-to-40MHz)-40MHz-now-!!!
The first variation might be easier to do in RegEx because it merely replaces showthread.php with 'discussion,' picks up the thread number which is at the start of the page URL. Vanilla specifies the canonical name of the thread in source (the latter example I show), so there's no duplicate content penalty. This is actually a VERY nice feature.
As a point of reference, the links above are not stored as [link]http: / /someurl...[/link], but are parsed as links every time the page is generated. So changes to the acceptable characters in a link need to be done at the parser level. I don't see how these characters (e.g. parentheses) can pose a security issue, as they're pretty common in URLs. Vanilla just doesn't like 'em.
An alternative might be to encode the ( and ) characters.
So close but yet...
Okay, if parsing embedded links in the old posts -- which I highly recommend for reasons I've already mentioned -- some characters will need to be encoded, namely ( and ), and perhaps others. I'd do a test to see which characters Vanilla likes and dislikes before writing any RegEx code for this.
