New forum "issue?" I can edit anyone's posts. — Parallax Forums
Is this just a moderator thing, as before, or can everyone do this? 'Just wanted to make sure, since moderator status in this forum is not made manifest.
  • SapphireSapphire Posts: 496
    edited 2015-07-01 03:00
    Phil,
    I just tried to edit yours, and could not.
    ____________
    Just testing ... I can  (all gone!).
    But, after your edit, I can still edit, and delete what you did!
  • But, interestingly, I can only do it once.
    edited 2015-07-01 03:01
    Once is enough, right?  Answer here ---> Unless I don't catch my dyslexia before hitting Svae Commnet. :)
  • Did you see how I deleted your edit to my first comment?
    edited 2015-07-01 05:31
    I do now, and I should hope that would always be possible. Checks and balances, and all that ......
    edited 2015-07-01 15:57
    It must be a moderator thing.  If I sign in with a different browser, the edit option is not there.   Phil, I added 3 more dots at the end of your previous post, on two separate occasions.  If you go away for a leap second and come back, the edit option reappears.
    Next day. I can edit my own post too, outside the 1 hour.
